Tom's Hardware Forums » Windows XP » Windows XP General Discussion » Need help!!, pc wont start after sp2 uninstall
Word :   Username :
Bottom
Author
 Thread : Need help!!, pc wont start after sp2 uninstall
More Information
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hey all,
I just uninstalled sp2 as I had a few error's in window's but now ufter
unistalling it I can't get into windows!!, it reboot's at the loading screen
(flashes a blue screen then reboot's) I've got so much on my pc I need
access to!!, can anyone help?.
I've tried the recovery but when I put in my password it says wrong password
when I know it's right.
Any help kindly apreciated.
Ellis
Related Product
Profile: stranger
More Information
rap wrote:
> Hey all,
> Ellis
If its XP home I think the password field needs to be blank. Try just
pressing enter at the password prompt without typing anything. Worth a shot.
John
More Information
Hi,
Thank's that worked, How do I repair using the recovery console, when I boot
in safe mode it stops at a347bus.sys so I need remove this as I think it's
causeing the problem.
TIA
"John" <John@nowhere.com> wrote in message
news:x6h1e.37988$FB6.3809@trndny09...
> rap wrote:
>> Hey all,
>> screen (flashes a blue screen then reboot's) I've got so much on my pc I
>> need access to!!, can anyone help?.
>> password when I know it's right.
>> Ellis
> shot.
> John
Profile: stranger
More Information
rap wrote:
> Hi,
> TIA
>>rap wrote:
>>>Hey all,
>>>Ellis
>>shot.
>>John
The only thing I can find Googling about is its a driver for 'Alcohol
120%', a CD/DVD backup program from what I gather. If you don't have
that software then I you will have to find out what software installed
it. If you delete the driver then obviously whatever doesn't work is
what uses it. There appears to be quit a few people having problems with
the driver runing XP,sp2 and W2K,sp4. If you know what installed it try
to get an updated driver.
John
More Information
Hi TIA,
Thanks for your post and John's information.
You said that when you boot in Safe Mode it stops at a37bus.sys. I agree
with you that the problem should be caused by it and we need to remove it.
Based on my research, please perform the following steps:
Step 1: Can you press ESC to cancel loading a347bus.sys? If you can,
please go to the system and delete a347bus.sys and a347scsi.sys from
\Windows\System32\Drivers\ these are the Alcohol drivers in latest version
of Alcohol (1.9.2.1705) and replace your atapi.sys with a valid one from
your current service pack. Then repair your windows install. If you
cannot, you can boot the system in DOS and use the delete command to delete
them.
Step 2: Repair Windows XP Installation
1. Place the Windows XP CD in the CD-ROM or DVD-ROM drive.
2. If the Windows CD displays the What would you like to do? menu, click
Exit.
3. Turn off your computer, wait ten seconds, and then turn your computer
back on.
4. If you are prompted to start your computer from the CD, do so.
5. After Windows XP Setup starts, press ENTER to continue the setup process.
6. Press ENTER to choose the option "To set up Windows XP now, press
ENTER". Do not choose the Recovery Console option.
7. Press F8 to accept the licensing agreement.
8. At this point, the Setup program will search for previous installations
of Windows XP.
- If Setup does not find a previous installation of Windows XP, then
you might have a hardware failure.
- If Setup does find a previous installation of Windows XP, then the
following message will appear:
If one of the following Windows XP installations is damaged, setup can
try to repair it. Use the up and down arrows to select an installation. To
repair the selected installation Press R. To continue without repairing,
Press Esc.
9. Choose the appropriate installation of Windows XP, and then press R to
attempt to repair it.
10. Follow the remaining directions on your screen.
Note: Some updates or drivers may need to be reinstalled after System
Repair.
For more detail about repair installation, please refer to link below:
KB315341: How to perform an in-place upgrade (reinstallation) of Windows XP
http://support.microsoft.com/defau [...] -us;315341
For more information:
http://www.anti-spy.info/process/a347bus.sys.html
If the issue persists, please let me know if there is any .dmp files or if
there is any blue screen errors.
Please take your time in trying the suggestions and let me know the result
at your earliest convenience. If you have any other questions or concerns,
please feel free to let me know. I'm looking forward to hearing from you.
Thanks & Regards
Amanda Wang[MSFT]
Microsoft Online Partner Support
When responding to posts, please "Reply to Group" via your newsreader so
that others may learn and benefit from your issue.
Business-Critical Phone Support (BCPS) provides you with technical phone
support at no charge during critical LAN outages or "business down"
situations. This benefit is available 24 hours a day, 7 days a week to all
Microsoft technology partners in the United States and Canada.
This and other support options are available here:
BCPS:
https://partner.microsoft.com/US/te [...] w/40010469
Others: https://partner.microsoft.com/US/te [...] toverview/
If you are outside the United States, please visit our International
Support page:
http://support.microsoft.com/defau [...] onal.aspx.
This posting is provided "AS IS" with no warranties, and confers no rights.
Google Ads
News
Intel enters the flash drive business
Published on March 12, 2007
Intel has entered the flash drive business by announcing its Z-U130 flash drive. Using NAND flash technology, the drive will come in 1, 2, 4 and 8 GB sizes and use a USB connector. Intel claims the drive will be speedy and will read at 28 MB/sec and write at 20 MB/sec. Read more
Samsung reveals 8G and 9G production schedules
Published on July 05, 2005
Samsung Electronics expects to start operating an eighth-generation (8G) TFT LCD plant in the second half of 2007, with a 9G plant to start volume production in 2009 at the latest, according to Sang Wan Lee, president of Samsung's LCD Business, as quoted by the South Korea-based Chosun Ilbo. Read more
Hitachi GST to start volume shipments of Mikey microdrives in 4Q
Published on September 07, 2005
Hitachi Global Storage Technologies (Hitachi GST) is expected to start volume shipments of its new-generation of microdrives, codenamed Mikey, in the fourth quarter of this year, according to Morse Chen, general manager for Hitachi GST Taiwan and Shanghai. Read more
Wikipedia goes mobile with Webaroo
Published on September 15, 2006
Wikipedia, the popular free online encyclopedia and web 2.0 mover and shaker of the moment, has been reverse-engineered to work offline. Read more
Latest Reviews & Articles
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
1,000 GB: Three Samsung TB Drives
Published on September 23, 2008
Storage vendors split the desktop hard drive market into performance, mainstream, and energy-efficient products. We looked at Samsung’s Spinpoint F, the RAID version and the EcoGreen F to discover how a 1,000 GB drive differs from another. Read more
