Tech: does mAH matter on a 3.6V replacement battery for Be..
Archived from groups: rec.games.video.arcade.collecting,rec.games.video.arcade (More info?)
So I stop by Radio Shack today to pick up a 3.6 volt cordless phone battery
to put in my Berzerk machine - as read about here... There are about twenty
3.6V batteries with mAH number of 600, 700, etc.
My question(s) are: what is this number and does it matter which one I buy
for Berzerk? Thanks in advance!
Steve
4 answers Last reply
More about tech matter replacement battery
  1. Archived from groups: rec.games.video.arcade.collecting,rec.games.video.arcade (More info?)
    Steve,
    mAH is milli-Amp Hours. It specifies how much current the battery can
    deliver for a period of time. For example, 600mAH can deliver 600
    milliAmps (0.6A) for one hour. Or, 1 milliAmp for 600 hours, or a
    variant inbetween. Take the battery's rating in mAH and divide that by
    the amount of current your circuit requires in mA and that's how long
    the battery will last in hours.
    - Craig
    battery
    twenty
    I buy
    > Steve
  2. Archived from groups: rec.games.video.arcade.collecting,rec.games.video.arcade (More info?)
    In other words, the higher the mAh rating, the longer the battery will last.
    Might as well make it a large one, and you're set for a long time=labor
    saved.
    "Craig Yarbrough" <hyarbr01@harris.com> wrote in message
    news:1115084425.501196.258650@f14g2000cwb.googlegroups.com...
    > Steve,
  3. Archived from groups: rec.games.video.arcade.collecting,rec.games.video.arcade (More info?)
    Got it. Thanks for the info!
    Steve
    > Steve,
    > - Craig
    > battery
    > twenty
    > I buy
    > > Steve
  4. Archived from groups: rec.games.video.arcade.collecting,rec.games.video.arcade (More info?)
    yea its weird i had a long argument with my brother about aas vs d
    batterys he said d batterys had much more power i agreed but i said
    they are the same voltage
    and if you could fit 2 ds in a walkman that uses aas it would work fine
    he thought ds would blow it up because they would provide more power
    3.6 volts is either some weirdo lithium batter or 3 nicads or nimh
    batterys
    since most arcade machines seem to be heald together with duct-tape and
    gum on the inside just get some rechargables and a battery holder or
    just solder them to make a pack
    i havent paid for rechargeables in a long time since they have those
    recycle bins
    i can get a few dead phone packs dissassemble them and find good cells
    and make good packs or use them individually most phone packs are 3
    batts and its the one connected to the negative lead that is internally
    shot bust up the pack
    find the cell that has low voltage and discard it back in the recycle
    bin or if they are all the same
    charge them up individually run em down in a flashlight and see which
    one dies first
    charging them till they are slightly warm and dischargin them in a
    flashlight will remove their cell memory after a couple cycles
Battery Games Video Video Games
