Strange XP Problem
Forum Windows XP : Windows XP General Discussion - Strange XP Problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I just reinstalled XP Home on my PC using a RAID 0 configuration for the
HDs. Everything installed fine until I installed the soundcard driver.
First of it upset the modem, then the USB devices stopped and I had to power
off / on to get back to windows. Only problem was my boot time went from 25
seconds to about 70 seconds. I ran bootvis and noticed the NIC delay was
about 30 seconds, I couldn't understand why this would be since I only
installed a sound card. I look in CPL/system/hardware and noticed a load of
WAN miniports under network adapters (PPOE, PPOA and some others, about 5 in
total). I have no idea where these came from. I disable them and rebotoed
and things seemed a little quicker. I then enable them and lo and behold
they disappeared. I am now back to a decent boot time but if anybody could
explain what happened and why it happened I would be most grateful.
Thanks,
Andy
Sponsored Links
Your NIC driver probably needs an upgrade.
Mark L. Ferguson (NOT an MS-MVP)
FAQ for MS Antispyware version 1.0.509
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
marfers notes for windows xp http://www.geocities.com/marfer_mvp/chatNotes.htm
"Andrew" <andrewportess@NOSPAMhotmail.com> wrote in message news:114op1mrstcvv8b@corp.supernews.com...
>I just reinstalled XP Home on my PC using a RAID 0 configuration for the HDs. Everything installed fine until I installed the
>soundcard driver. First of it upset the modem, then the USB devices stopped and I had to power off / on to get back to windows.
>Only problem was my boot time went from 25 seconds to about 70 seconds. I ran bootvis and noticed the NIC delay was about 30
>seconds, I couldn't understand why this would be since I only installed a sound card. I look in CPL/system/hardware and noticed a
>load of WAN miniports under network adapters (PPOE, PPOA and some others, about 5 in total). I have no idea where these came from.
>I disable them and rebotoed and things seemed a little quicker. I then enable them and lo and behold they disappeared. I am now
>back to a decent boot time but if anybody could explain what happened and why it happened I would be most grateful.
> Thanks,
> Andy
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Strange XP Problem
There are 917 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
