Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi,
I have an external firewrie drive and I want to copy a file from it to
the internal HD. The file is over 1GB big, and the constant message
comes up that the connection to the HD is interrupted. I then need to
connect it again, but it still does not work. I looked up in the event
viewer, and apparently it can happen that files bigger than 128kb
cannot be read/copied on external HD. Very strange as I used to do it
before. The HD I had in the firewire enclosure was a Wester Digital
160GB ATA-100. No problem with that one. Now, that I replaced it with a
Wester Digital 120GB ATA-100 (same enclosure) I have this problem that I
cannot copy bigger files. Please help,
Thanks,
Catalin
OS: XP (SV1)
cbrylla
Sponsored Links
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problems external HD
There are 1266 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
