Caps Lock light - how do I get it to turn on again?
ctech
14
I removed my laptop keyboard, then re-installed it. After putting it back together, at first the CapsLock light was off, then it was dim, now its completely out. When it was dim, it would get a little brighter when I jiggled it. I took off the key to see if there was a visble problem under the CapsLock key. After putting it back on, now its not even dim.
When I disassembled the laptop, I disconnected 3 cables that hook the keyboard to the laptop. Perhaps when I put it back together one didn't go in correctly?
Do you know WHICH CABLE controls the caps lock key light. Normally when CAPS ARE ON, it should be lit.
The fuctionality of it going to ALL CAPS works
The sound of the high pitch to turn on and low pitch to turn off works
The LIGHT when CAPS LOCK is on NO LONGER WORKS.
The light that is above the number lock key still works. The panel lights for sound still work.
Suggestions?
