help i messed with my graphics card!
holliswhy
35
I have a Grandmars VIA 266 motherboard 7VJD, I was messing with my display card, changing it from Geforce 5200 to Geforce 4 MX, but when i booted up the PC it shows a funny srceen, so I cleared the bios and tried again, which didn't work!!!!! So I putted the Geforce FX 5200 back and system is fine again!
But because my little brother Fxxx my XP so i needed to format and reinstall.
During XP installing a Blue srceen came up which says something like '...IRQ and less or equal..' and the system is halt. i tried it a few times with different windows CD, but it doesn't work! i tried it with a geforce 2MX and the same thing happened. but windows 2000pro installation is fine! and i am using that now!
Also, when i restart the pcthe system halts and doesn't startup again, and needs to reset with the reset switch! whats going !!!?!!?? help!!!??!?!
I love my pc
but my pc hates me...
