Help with a Laptop Battery replacement
hilltopmonk
258
Hi all,
I have a laptop and the battery has died, as by died i mean that it refuses to charge above 5% - meaning it it pretty much useless.
First, the specs.
Laptop - Acer Aspire 5741G
Battery - AS10D31 (Li-ion 00, 10.8V 4.15 Ah , 4400mAh 48Wh)
Now the question;
The replacement batteries I have come across have different voltage (11.1V) supplied. Is it fine to use these in my laptop, seeing as these are the recommended batteries for the laptop?
I have found some which have the same voltage, but at the same price the extra charge (extra 9Wh) seems a better option to go with.
Thanks all,
