Along time ago I did a foolish thing to my ancient graphics card - I decided to update the TNT2 Detonator drivers from version 21.83 to about 40.xx and then none of my DirectX games would run. Then, I introduced a program called Detonator Destroyer which totally uninstalled my drivers - I then started building the card from scratch - first using the Sparkle drivers included with the card, then I reinstalled version 21.83 again; the version I started off with and was using happily before all of this palaver happened.
However I then found that my Direct 3D settings were ruined - there was an nVidia logo in the corner of the screen and in many games I can't seem to change any options regarding the resolution or refresh rate. I have lost some options with Direct3D and I am gven options regarding Anti Aliasing which my card doesn't even support. I thought I could correct this problem by installing DirectX 9.
I have problems when playing grand theft auto 3 - it only requires a 16MB DirectX 8.1 compatible card and mine is 32MB. The graphics are really appalling and even on minimal settings the game runs really slow.
I tried to go into DirectX 9 Diag and under the graphics heading it said that AGP Acceleration was disabled - with my old drivers it was enabled and when I used 40.xx drivers the Direct3D tests wouldnt even run! I cant even enable AGP Acceleration now but the tests all ran fine and successfully.
As you can see all of my actions have had chain reactions making the problem worser and worser. Please can someone help me rectify the problem by telling me:
- Which version of drivers I need install
- The website which I can obtain the appropriate drivers
- How to install the drivers
Before I did all of the above all DirectX games were working fine, if a little slow when running the resolution on 1024 x 768. I guess the moral is if I aint broke dont fix it. LOL Screw the moral - help me get back all the options I had with "old" 21.83 setup and allow me to carry on enjoying games the way I used to!
PC Spec
ECS K7S5A with Sis Chipset
AMD Athlon XP 2000+
768MB PC133 SDRAM
10GB Hard Disk space with only 300MB remaining!
16x LG DVD ROM drive
Memorex 24Maxxx1040 CDRW drive
Creative Sound Blaster Audigy 2 Soundcard
Creative Inspire 6.1 6700 Speakers
Sparkle nVidia Riva TNT2 32MB M64 AGP Graphics card (I dont know if it is DirectX 9 compatible:-s)
Windows Me
Thank you guys for your time!
The PC Guru knows all except combination to the safe! Check out my PC Guru website @ www.geocities.com/marshahu_cr - It's still under development
PC Spec
AMD Athlon XP 2000+
768MB PC133 SDRAM
Windows Me
