HELP! Can't connect to my wireless network
Hey everyone thanks for taking your time to read this and hopefully, thanks for helping me figuring the problem im facing in advance.
So in short im having problems with my internet wireless connection when i try to connect to the network it fails it gives me a message: Windows cannot connect to SpeedTouch and it gives me the option of diagnose the problem or connect to a diffrent network when i choose the first one it gives me another message saying Wireless association failed due to unknown reason, and it gives me two other option. The thing is no matter what i do nothing works. All other devices can connect to it with no problem excempt my laptop. The laptop have randomly connected like 2 times the first time was for a couple of hours the second time was just for about 30mins.
Now, everything started about 3 days ago. When i woke up from a nap i noticed that i had no connection so when i tried connecting to it, it game me the same messages i explained, so i spended the whole day trying to fix it unsuccesfuly. At some point i thought that my "cousin in law" had blocked my ip, but i really wouldnt know if i was so i instead kept trying to fix it by doing this:
1.Delete the network and re-enter the password.
2.System restore.
3.Updating the driver
So it wasnt until i tried the last one that it fix it, and it lasted about for 6-8hours the moment i went sleep and when i woke up again nothing it wasnt working and it havent done so since then. I have tried the same thing i did to fix it but nothing. So please, if anyone can help me ill be really greatful.
The laptop spec is:
OS: Vista
CPU: Intel Pentium Dual 1.86GHz
RAM: 2GB
Display: Mobile Intel 965 Express Chipset Family
Wireless Adapter: Intel Wireless WifiLink 4965AGN
(*When i go to System Information and in the Network Adapter part it says: "Name: (00000000) WAN Miniport (L2TP) Adapter Type: Not available, should it say the info above?)
GENERAL:
Helper Class (AutoConfig Helper Class) Event:
Wireless Diagnostic Helper Class Event
For complete information about this session see the Wireless Diagnostic Informational Event.
Helper Class: Auto Configuration
Initialize status: Success
Information for connection being diagnosed
Interface GUID: 3168298b-2f6c-4678-bdce-513a9366284d
Interface name: Intel(R) Wireless WiFi Link 4965AGN
Interface type: Native WiFi
Profile: SpeedTouch Orlando
SSID: SpeedTouch Orlando
SSID length: 18
Connection mode: Infra
Security: Yes
Connect even if network is not broadcasting: No
Result of diagnosis: Problem found
Issue referred to: RNWF MSM Helper Class
Root cause:
Windows could not connect to "SpeedTouch Orlando"
You can try to connect again.
Repair option:
View available wireless networks
You can then try connecting to "SpeedTouch Orlando" again or try connecting to a different network.
If you own or set up this network, reset your wireless router or access point and try connecting again.
Event Verbosity:0
DETAILS:
- System
- Provider
[ Name] Microsoft-Windows-Diagnostics-Networking
[ Guid] {36c23e18-0e66-11d9-bbeb-505054503030}
EventID 6100
Version 0
Level 4
Task 12
Opcode 0
Keywords 0x4000000000000002
- TimeCreated
[ SystemTime] 2012-05-09T00:59:19.116Z
EventRecordID 4467559
- Correlation
[ ActivityID] {2C01ADA9-382E-4B35-B3EF-2F90C6DC60F5}
- Execution
[ ProcessID] 5364
[ ThreadID] 6048
Channel System
Computer Angie-PC
- Security
[ UserID] S-1-5-19
- EventData
HelperClassName AutoConfig Helper Class
EventDescription Wireless Diagnostic Helper Class Event For complete information about this session see the Wireless Diagnostic Informational Event. Helper Class: Auto Configuration Initialize status: Success Information for connection being diagnosed Interface GUID: 3168298b-2f6c-4678-bdce-513a9366284d Interface name: Intel(R) Wireless WiFi Link 4965AGN Interface type: Native WiFi Profile: SpeedTouch Orlando SSID: SpeedTouch Orlando SSID length: 18 Connection mode: Infra Security: Yes Connect even if network is not broadcasting: No Result of diagnosis: Problem found Issue referred to: RNWF MSM Helper Class Root cause: Windows could not connect to "SpeedTouch Orlando" You can try to connect again. Repair option: View available wireless networks You can then try connecting to "SpeedTouch Orlando" again or try connecting to a different network. If you own or set up this network, reset your wireless router or access point and try connecting again.
EventVerbosity 0
4 answers Last reply
More about help connect wireless network
  1. And if it helps this is how the Network Diagnostic looks when it actually works, just about 5minutes ago started working for about 30mins and it disconnected again.
    SSID length: 18
    Security: Yes
    Connection incident diagnosed
    Auto Configuration ID: 15
    Connection ID: 21
    Connection status summary
    Connection started at: 2012-05-08 20:59:02-009
    Profile match: Success
    Pre-Association: Success
    Association: Fail
    Security and Authentication: Not started
    List of visible access point(s): 1 item(s) total, 1 item(s) displayed
    BSSID BSS Type PHY Signal(dB) Chnl/freq SSID
    00-1B-9E-9C-3F-38 Infra g -60 11 SpeedTouch Orlando
    Connection History
    Information for Auto Configuration ID 15
    List of visible networks: 1 item(s) total, 1 item(s) displayed
    BSS Type PHY Security Signal(RSSI) Compatible SSID
    Infra g Yes 66 Yes SpeedTouch Orlando
    List of preferred networks: 1 item(s)
    SSID length: 18
    Security: Yes
    Set by group policy: No
    Connectable: Yes
    Information for Connection ID 21
    SSID length: 18
    Security: Yes
    Pre-Association and Association
    Connectivity settings provided by hardware manufacturer (IHV): No
    Security settings provided by hardware manufacturer (IHV): No
    Profile matches network requirements: Success
    Pre-association status: Success
    Association status: Fail 0x00038002
    Association reason code: 0x00030001
    Information for Auto Configuration ID 14
    SSID length: 18
    Security: Yes
    Connectable: Yes
    Information for Connection ID 20
    Connection started at: 2012-05-08 20:58:58-531
    Auto Configuration ID: 14
    SSID length: 18
    Security: Yes
    Information for Connection ID 19
    Connection started at: 2012-05-08 20:58:53-048
    SSID length: 18
    Security: Yes
    Association status: Fail 0x00038001
    Association reason code: 0x00000000
    Information for Auto Configuration ID 13
    Infra g Yes 65 Yes SpeedTouch Orlando
    SSID length: 18
    Security: Yes
    Connectable: No
    Reason: 0x00028006
    Information for Connection ID 18
    Connection started at: 2012-05-08 20:57:47-979
    Auto Configuration ID: 13
    SSID length: 18
    Security: Yes
    Event Verbosity:0
    DETAILS:
    - System
    - Provider
    EventID 6100
    Version 0
    Level 4
    Task 12
    Opcode 0
    - TimeCreated
    [ SystemTime] 2012-05-09T00:59:19.112Z
    EventRecordID 4467558
    - Correlation
    - Execution
    [ ProcessID] 5364
    [ ThreadID] 6048
    Channel System
    Computer Angie-PC
    - Security
    [ UserID] S-1-5-19
    - EventData
    EventDescription Wireless Diagnostic Informational Event Information for connection being diagnosed Interface GUID: 3168298b-2f6c-4678-bdce-513a9366284d Interface name: Intel(R) Wireless WiFi Link 4965AGN Interface type: Native WiFi Profile: SpeedTouch Orlando SSID: SpeedTouch Orlando SSID length: 18 Connection mode: Infra Security: Yes Connect even if network is not broadcasting: No Connection incident diagnosed Auto Configuration ID: 15 Connection ID: 21 Connection status summary Connection started at: 2012-05-08 20:59:02-009 Profile match: Success Pre-Association: Success Association: Fail Security and Authentication: Not started List of visible access point(s): 1 item(s) total, 1 item(s) displayed BSSID BSS Type PHY Signal(dB) Chnl/freq SSID ------------------------------------------------------------------------- 00-1B-9E-9C-3F-38 Infra g -60 11 SpeedTouch Orlando Connection History Information for Auto Configuration ID 15 List of visible networks: 1 item(s) total, 1 item(s) displayed BSS Type PHY Security Signal(RSSI) Compatible SSID ------------------------------------------------------------------------------ Infra g Yes 66 Yes SpeedTouch Orlando List of preferred networks: 1 item(s) Profile: SpeedTouch Orlando SSID: SpeedTouch Orlando SSID length: 18 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: Yes Information for Connection ID 21 Connection started at: 2012-05-08 20:59:02-009 Auto Configuration ID: 15 Profile: SpeedTouch Orlando SSID: SpeedTouch Orlando SSID length: 18 Connection mode: Infra Security: Yes Pre-Association and Association Connectivity settings provided by hardware manufacturer (IHV): No Security settings provided by hardware manufacturer (IHV): No Profile matches network requirements: Success Pre-association status: Success Association status: Fail 0x00038002 Association reason code: 0x00030001 Information for Auto Configuration ID 14 List of visible networks: 1 item(s) total, 1 item(s) displayed BSS Type PHY Security Signal(RSSI) Compatible SSID ------------------------------------------------------------------------------ Infra g Yes 66 Yes SpeedTouch Orlando List of preferred networks: 1 item(s) Profile: SpeedTouch Orlando SSID: SpeedTouch Orlando SSID length: 18 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: Yes Information for Connection ID 20 Connection started at: 2012-05-08 20:58:58-531 Auto Configuration ID: 14 Profile: SpeedTouch Orlando SSID: SpeedTouch Orlando SSID length: 18 Connection mode: Infra Security: Yes Pre-Association and Association Connectivity settings provided by hardware manufacturer (IHV): No Security settings provided by hardware manufacturer (IHV): No Profile matches network requirements: Success Pre-association status: Success Association status: Fail 0x00038002 Association reason code: 0x00030001 Information for Connection ID 19 Connection started at: 2012-05-08 20:58:53-048 Auto Configuration ID: 14 Profile: SpeedTouch Orlando SSID: SpeedTouch Orlando SSID length: 18 Connection mode: Infra Security: Yes Pre-Association and Association Connectivity settings provided by hardware manufacturer (IHV): No Security settings provided by hardware manufacturer (IHV): No Profile matches network requirements: Success Pre-association status: Success Association status: Fail 0x00038001 Association reason code: 0x00000000 Information for Auto Configuration ID 13 List of visible networks: 1 item(s) total, 1 item(s) displayed BSS Type PHY Security Signal(RSSI) Compatible SSID ------------------------------------------------------------------------------ Infra g Yes 65 Yes SpeedTouch Orlando List of preferred networks: 1 item(s) Profile: SpeedTouch Orlando SSID: SpeedTouch Orlando SSID length: 18 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: No Reason: 0x00028006 Information for Connection ID 18 Connection started at: 2012-05-08 20:57:47-979 Auto Configuration ID: 13 Profile: SpeedTouch Orlando SSID: SpeedTouch Orlando SSID length: 18 Connection mode: Infra Security: Yes Pre-Association and Association Connectivity settings provided by hardware manufacturer (IHV): No Security settings provided by hardware manufacturer (IHV): No Profile matches network requirements: Success Pre-association status: Success Association status: Fail 0x00038002 Association reason code: 0x00030001
    EventVerbosity 0
  2. First off check to see if someone changed the setting on your router. i would start there by holding the reset button on the router and put it back to factory settings. when it powers back on you should be able to connect to it as it wont have a password. if you can log onto the internet then you know the error was a settings issue. you can then log into the router (1923.168.1.1) change the name of the wifi and put a password back on it. if you think it the wifi card then connect the laptop by hard wire to the router and if it connects try updaing the wifi software for the wifi card.
  3. Well i cant change the settings of the router because my cousins husband is the owner of it and would like to refrain from doing so unless absolutly necessary or unless i can change the password and name of the connection as it was before... And i already have updated the adapter drivers :( any other suggestion
  4. Try to restore the router to the factory mode by press the bottom behind the router for ten second until the router lights turn on and off many time ........then go to the laptop open the wireless by bottom or some one of f function. Go to the network manager. And delet the laptop icons that is using the lasts passwords of networks ..go to IP address to ensure the is no ip and it's in. Automatics IP address ..also try to delet the driver of wireless card and install new open by cd or connect to Ethernet.port. ...ther driver from original company ....try this and I hope it will solve
Wireless Connection Wireless Network Laptops
