Closed Solved
Windowns 7 problem
Hello,
my soundmax didnot work were to find a driver,
and the windows 7 that i buy is not genuine were can i find key for that..
thanks..
3 answers Last reply Best Answer
More about windowns problem
  1. Best answer
    If you purchased windows 7 from a store, return it and get a new copy. If you downloaded it illegally, shell out the money and pay for it. As far as your drivers go, if you own a custom built system you will have to go to the manufacturer's website of either you motherboard or your sound-card if you have a sound-card. If you have a pre-built system then visit their manufacturer's website. ie. dell.com hp.com etc.
  2. Well said fusion_gtx. We do not discuss software piracy here on the forums- buy it.
  3. Best answer selected by buwish.
Drivers Windows 7
