Need help with cooling graphics card
Icecore
Hello,
I've had some problems with my computer for awhile. When playing games the computer has just restarted itself or I've got a blue screen. I put the computer by the window and opened it, the games did not lock the computer anymore. So I figure it must be a problem with overheating. I've got 2 germans and one other guy having the same problems with the same card, ASUS nVidia Ti4200, in my case model V8420S. The last mentioned guy says he fixed his problems and that it was overheating that caused it. He hasn't replied on what he did to fix it. I'm no hardware-pro so can you give me any tips on how to cool down the graphics card? I have my chassi open but the problem is still there, it isn't enough.
Karl
cleeve
Illustrious
You have to pump air through that mofo. AIRFLOW IS KEY.
Get two case fans... put one bringing air in in the front of the computer under all of the drives, then put one forcing air out under the power supply in the rear.
________________
<b>Radeon <font color=red>9500 PRO</b></font color=red> <i>(hardmodded 9500, o/c 322/322)</i>
<b>AthlonXP <font color=red>2600+</b></font color=red> <i>(o/c 2400+ w/143Mhz fsb)</i>
<b>3dMark03: <font color=red>4,055</b></font color=red>
addiarmadar
2,558
Ive heard alot of overheating issues with the ASUS ti4200 models. Most just put a 80mm fan blowing on the HSF.
Barton 2500+ @ 2200mhz (10x220 vcore @ 1.8)
Asus A7N8X Dlx 440 FSB
1gb Geil GD pc3500 Dual Channel (2-3-3-6)
Segata 80gb SATA 8.5ms seek
ATI Radeon 9800 Pro(420/720)
Crashman
Polypheme
Former Staff
First thing I'd do is make sure there isn't a PCI card in the next slot down, they interfere with airflow to the card.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
pauldh
Illustrious
Depends on your case. Most use an 80mm fan. If your case doesn't have anywhere to mount an exhaust fan, one of these pci slot fans can move alot of air out the back of the case. Place it in the empty slot right under your video card (PCI slot 1)
http://www.nexfan.com/syexbl.html
ABIT IS7, P4 2.6C, 512MB Corsair TwinX PC3200LL, Radeon 9500 Pro, Santa Cruz, Antec 1000AMG, TruePower 430watt
