Building cabinet with TV
G
Guest
Guest
Archived from groups: rec.games.video.arcade (More info?)
Hi all.
I'm currently planning to build a non-mame cabinet
with a TV as monitor.
My question is do I need anything else besides the tv,
jamma harness, pcb's, cp and a switching power supply?
I read the article on wiring AC at Bob Roberts page
(http://homearcade.org/BBBB/)
about using an isolation transformer, ac fil´ter, etc..
But these thing seems to be more related to using a arcade
monitor.
Since the tv and possibly the marquee light will just be
connected to a regular wall socket using normal connections.
Am I correct in assuming this? Don't have much knowledge
about electrical stuff so I thought I would check up on this.
Thank you /T
G
Guest
Guest
Also need an RGB to NTSC Converter
<tedronai@infoseek.jp> wrote in message
news:1125795033.842804.76600@g47g2000cwa.googlegroups.com...
Hi all.
monitor.
Thank you /T
G
Guest
Guest
What are you planning on using for a game? One of the consoles like
XBox or PS2 or Dreamcast or are you going to use a traditional arcade
boardset?
IF the first, you won't need an ntsc converter. If the latter, you
will. I've seen a few cabs with the dreamcast system installed and they
looked pretty cool and were probably a little more reliable than the
original games were.
Pat D.
tedronai@infoseek.jp wrote:
> Hi all.
> monitor.
> Thank you /T
G
Guest
Guest
yeah I wouldnt mind putting my dreamcast and house of the dead into a
cabinet!!! that would be fun!!
AF
"Pat Danis" <patdanis@NOSPAMverizon.net> wrote in message
news:rn2Te.13161$B34.11122@trnddc09...
> boardset?
> Pat D.
> > Hi all.
> > monitor.
> > Thank you /T
G
Guest
Guest
Since I live in Europe my TV has rgb scart so that wont be a problem.
Thnx for the input =)
/T
G
Guest
Guest
forgot to say that I will be building a classic jamma cab
with switchable pcb's.
/T
