Dell Latitude E6510 new battery not charging on AC power
pcakkus1
Hi!
I have the following problem:
After 3 years, the battery of my Dell Latitude E6510 given up the ghost and I've bought a new (not a replica but the original model purchased from http://www.pcakkus.com/dell-latitude-e6510.html ).
The battery can be used easily and is also recognized by the system.
Only problem: He can not be charged.
When you first insert the battery was at 33%. In network mode, it remains at 33%. However, it is shown: left 33% (network operation is not recharged).
Have already taken out the battery again and blown onto the contacts and everything wiped cloth with NEM (thought it might be a bit dusty). But nothing helps.
Can someone help me? Were so thankful for every tip.
He had an OEM Dell battery though, so it should have been working fine with the laptop.
The battery from that site looks to be non OEM either, although a lot more expensive than the Chinese batteries from ebay.
marty8683
Pretty sure this has been resolved since it's so old.
I have a cat that likes to sit on my keyboard when I'm not around and she somehow gets into the power settings and checks the box beside "Disable Battery Charging".
I uncheck this setting and the battery charges fine.
Hope this helps someone out there.
