G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
When right clicking a file, there used to be an option to "Open With" and
then a listing of programs I could select to open the file with. For some
reason the Open With heading has gone. Is there any way I can get this
heading back.
Thanks
G
Guest
Guest
Go to Start | Run
Type in regedit and click ok
This will open the registry editor
In the left hand pane, find the following key
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\shellex\ContextMenuHandlers\
Is there a folder called Open With?
> heading back.
> Thanks
G
Guest
Guest
At the location
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\shellex\ContextMenuHandlers\ there is
a folder called Open With and there is a Default String value data of @"".
