Help with Centipede monitor adjustment
Archived from groups: rec.games.video.arcade.collecting (More info?)
I just had a cap kit installed for a friends centipede upright. The
problem is I need to adjust the vertical because the sides are too
wide. Can someone tell me where it's located. I found the ones for
color, brightness & focus. Is it one of those silver adjustment knobs
that you need a tool for ??? Thanks in advance.
Chas
6 answers Last reply
More about help centipede monitor adjustment
  1. Archived from groups: rec.games.video.arcade.collecting (More info?)
    You will need to find out the make and model of the monitor installed in
    order for anyone to be able to help you. You should find some lavbels
    of some sort that will guide you. More than likely your monitor is
    either a Zenith, Wells Gardner, Electrohome, or other. Just write down
    all the info you can find on the labels affixed to the metal chassis and
    frame of the monitor. The numbers on the tube won't help.
    Once you give us this, we can help.
    Pat D.
    > Chas
  2. Archived from groups: rec.games.video.arcade.collecting (More info?)
    Here is my monitor model info people.. Thanks!
    Electrohome Electronics
    Model# 19" Col Gam Mtr
    Product # 38-G07904-I0
    Chasis# G07CB0
    Serial 9-976056
    Chas
    in
    lavbels
    down
    and
    > Pat D.
    knobs
    > > Chas
  3. Archived from groups: rec.games.video.arcade.collecting (More info?)
    I think I found a site that has a pic with my monitor showing which one
    to adjust. Can someone verify this IS the correct one? Thanks
    Chas
    http://forum.arcadecontrols.com/index.php/topic,4087.0.html
  4. Archived from groups: rec.games.video.arcade.collecting (More info?)
    Chas
  5. Archived from groups: rec.games.video.arcade.collecting (More info?)
    Yep. That is it. Left to right, the adjusting pots are:
    Vert. Hold.
    Vert Linear. (you may need to adjust this one a little if the pictures
    or sprites look fatter than others)
    Vertical Height. (This is the one you are looking for)
    Horzontal Freq.
    and finally,
    Horizontal Centering.
    As you so aptly poointed out, since your monitor is a vertical mount,
    you need to adjust the "vertical height" to change the horizontal width
    and vice versa.
    There is a good description on how to adjust the monitor properly on Bob
    Robert's site . If you scroll down to the bottom and look at the
    "bulletin board " sectiona nd look for the G07 "vertically challenged"
    article, that should help a lot. While you are there, read all the
    other stuff and be sure to order replacement parts from Bob. He has
    been a tremendous help to this hobby.
    http://www.therealbobroberts.com/
    Good luck.
    Pat D.
    > Chas
  6. Archived from groups: rec.games.video.arcade.collecting (More info?)
    Thanks. That is exactly what I needed to know. :)
    > Vert. Hold.
    pictures
    > Horzontal Freq.
    > and finally,
    width
    > and vice versa.
    Bob
    challenged"
    > Good luck.
    > Pat D.
    one
    > > Chas
Monitors Video Games
