G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi,
I connect to internet via broadband through a BT Voyager Wireless Router.
Recently, I have noticed that the connection seems to drop.
I can connect to http://ukpetsonline.com. No problem, but if I then try to
connect to http://ukpetsonline.co.uk the Dial Up Connection dialogue box
appears, if I try to connect the connection fails. If I then try to go back
to http://ukpetsonline.com I get the message that I am offline and do I want
to connect which then connects OK.
Why does the connection drop out and how can I stop it happening?
It does this with other connections not just http://ukpetsonline.co.uk
Hi,
