G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Greetings
I recently installed Windows XP as part of a dual boot system. The
oldest (and first) OS is Windows 98
Win 98 is installed on the C:\ drive. WinXP is installed on another
partition.
As Win XP was installing I noted that it had difficulty copying the
search assistance and help and support files and I had to skip these.
Help and support does not appear as one of the services in
msconfig.exe
Neither the PCHEALTH nor Srchasst directories were put in place in the
Windows.
Clicking on Health and Support in Start resulted in a file not found
error for hlpcenter
I located the .inf files for the Help Center and for Search Assistant
managed to get all the files in place. Both the directories were
created. All the files were in place. Clicking on the Help and Support
icon in Start resulted in nothing at all - not even an error message.
Nor is the Search Assistant in the file search utility which is less
than effective without it.
Are my problems because I have chosen a dual boot system or am I
missing something. All the Registry Keys are in place but Help and
Support and still not visible as services in msconfig.exe
Cheers
David Harvey
Greetings
partition.
msconfig.exe
Windows.
error for hlpcenter
Cheers
David Harvey
