where can you buy a mounting bracket for sound pots?
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I checked the usual places and have not seen them. I need to mount a sound
pot in a williams game.
G
Guest
Guest
Go to a Home Depot, Lowes, or a Hobby/Craft store and look for one of
those long "L" brackets, cut it to length, and drill clearance holes.
Marcel
G
Guest
Guest
Just get a small piece of sheet metal bend it into a 90 degree angle and
drill the hole for the pot and usually the smaller hole for the retainer
piece and mount it. That's why I typically have to do. Old school Atari
power supplies sometimes still have a nice piece of sheet metal on the
bottom of them if you have some junked ones laying around.
Scott
www.agelessarcade.com
"Jason Souza" <jsouza@verizon.net> wrote in message
news:XuDXd.64056$W16.31532@trndny07...
sound
