G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I've got a couple of Defender machines - neither working, and am having trouble
getting either of them to work.
Voltages are all good at the chips. I've done the -5/+12 mod so I can run 4164s
in the board instead (and I've verified the voltages at the chips and they're
all OK!), but the symptoms described below occurred even before I did the 4164
RAM swap.
The !RESET signal @ the 6809 oscillates at a rate of about 4Hz. Obviously it's
not getting very far. ;-( *BOTH* Boards do the same thing.
Pin 9 of the AND gate @ 6O is high, and it's pins 10 and 11 that are toggling @
4Hz. Tracing that back to the counter @ 5O, the output of Q1 (pin 6) is
oscillating. Pin 2 of the 74393/5O (CL) is low, and the clock input is
oscillating at a much higher rate than pin 6 of 5O.
It all seems kinda odd that it's allowing that /16 clock to get fed through to
the gates that control the reset. Shouldn't pin 2 of the 74393 (clear line) be high?
Anyway, if anyone has any thoughts as to how to proceed, I'd appreciate it!
-->Neil
RAM swap.
-->Neil
