Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi,
I'm trying to upgrade to Windows XP from ME, but when i try to install the
program onto my PC i get a "Blocking Issue" problem and a message saying :
"Before setup can be completed, you must uninstall these programs from your
computer.
Microsoft Shared Fax Client
Your existing Microsoft Fax application will not be available after
upgrading to Windows XP, and will be replaced by the Windows XP Fax. Please
uninstall this fax application using Add/Remove Programs in the Control
Panel, and then restart to upgrade."
OK so i followed those instructions, but the problem is that i can't find a
Program named 'Microsoft Shared Fax Client' among my Add/Remove Programs
list.
Can someone please tell me what i'm doing wrong and possibly provide an
extreme dummies guide to removing Microsoft Shared Fax Client from a PC?
Thanks in advance.
Hi,
computer.
list.
Thanks in advance.
