Help Changing MB use same HD w/OS
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I want to change my motherboard (upgrade) in my PC. Can I do this with out
doing a clean reinstall of XP Pro?
What step should I take to use the same harddrive w/ XP Pro OS on it and all
of the other programs?
Bobby Atkinson
batkinson@iquest.net
More about : changing
Normally, and assuming a retail license (many OEM installations are
not transferable to a new motherboard - check yours before starting),
unless the new motherboard is virtually identical (same chipset, same
IDE controllers, same BIOS version, etc.) to the one on which the WinXP
installation was originally performed, you'll need to perform a repair
(a.k.a. in-place upgrade) installation, at the very least:
How to Perform an In-Place Upgrade of Windows XP
http://support.microsoft.com/directory/article.asp?ID=K...;EN-US;Q315341
The "why" is quite simple, really, and has nothing to do with
licensing issues, per se; it's a purely technical matter, at this point.
You've pulled the proverbial hardware rug out from under the OS. (If
you don't like -- or get -- the rug analogy, think of it as picking up a
Cape Cod style home and then setting it down onto a Ranch style
foundation. It just isn't going to fit.) WinXP, like Win2K before it,
is not nearly as "promiscuous" as Win9x when it comes to accepting any
old hardware configuration you throw at it. On installation it
"tailors" itself to the specific hardware found. This is one of the
reasons that the entire WinNT/2K/XP OS family is so much more stable
than the Win9x group.
As always when undertaking such a significant change, back up any
important data before starting.
This will also probably require re-activation, unless you have a
Volume Licensed version of WinXP Pro installed. If it's been more than
120 days since you last activated that specific Product Key, you'll most
likely be able to activate via the Internet without problem. If it's
been less, you might have to make a 5 minute phone call.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
when you plug your hdd into your new motherboard, boot off the win xp
cd - not off the hdd. run the win xp repair off the cd (this is not R
for recovery console, but more like <enter> - as iof you're gonna
install xp then R )
Changing a Motherboard or Moving a Hard Drive with XP Installed
http://www.michaelstevenstech.com/moving_xp.html
How to Perform a Windows XP Repair Install
http://www.michaelstevenstech.com/XPrepairinstall.htm
[Courtesy of MS-MVP Michael Stevens]
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
Get Windows XP Service Pack 2 with Advanced Security Technologies:
http://www.microsoft.com/athome/security/protect/window...
| Bobby Atkinson
Thanks
I will try this and hope for the best. will repost when I am completed the
task. My take a week or so.
Bobby Atkinson
"Carey Frisch [MVP]" <cnfrisch@nospamgmail.com> wrote in message
news:%23x8ZNo8PFHA.2972@TK2MSFTNGP14.phx.gbl...
> Carey Frisch
> Microsoft MVP
> out
> all
> | Bobby Atkinson
Ask the community
