Tom's Hardware > Forum > Games General > Games General Discussions > Tech: Kortek monitor woes
Forum Games General : Games General Discussions - Tech: Kortek monitor woes
Archived from groups: rec.games.video.arcade.collecting (More info?)
Kortek monitor woes is right.
This monitor was working fine last Christmas. I lost the blue color
just before I was going to sell it to a customer. I set it aside until
now and troubleshot it.
Found the Q107 neckboard transistor had been bent too far and pulled up
a trace on the mounting pad.
I removed the transistor and fixed the trace and then reinstalled the
transistor.
I had a blue color for just a brief second. The I lost it again.
I pulled the chassis and found that Q104 and Q152 were bad. Replaced
those and tried again. No dice.
This time I took a closer look at the neckboard area and found that I
had installed the Q107 neck board transistor backwards.(Duh) Pulled it
and checked it and it tested good. Replaced the chassis mounted
transistors and tried again.
No luck still. I pulled all the transistors and found that I am still
killing the chassis mounted transistors Q103,Q104, and Q152. Q107 is good.
Where do I go from here? What is killing these transistors?
Is it a result of mounting the neckboard transistor incorrectly? I sure
would appreciate somebody's expertise here. I'm running out of patience
and spare transistors.
Thanks
Pat
Sponsored Links
for your information, the kortek is the same as an imperial monitor chassis.
Which the manual for it is available on the net.
"Pat D" <patdanis@comcast.net> wrote in message
news:MZWdneCY28zL46vfRVn-1w@comcast.com...
> transistor.
good.
> Thanks
> Pat
Reply to Vaxx
> sure would appreciate somebody's expertise here. I'm running out of
> patience and spare transistors.
Have you tried swapping the color outputs to see
if the problem is the tube ? I've got a bunch of
these and have the same problem with a couple. Change
the transistor, works good, button it up, walk by it
later and no blue again.
Reply to Anonymous
- 0 +
Have you tried checking the tube itself with a CRT Checker? I have run
into the same problem and found that one of the guns was going bad. A
little magic with the Rejuventator and problem solved.
Good Luck
RJ
of
Reply to RJ
Tube tested good earlier but I haven't rechecked it yet. I'll shoot it
later this morning when I get a chance and see what is going on.
Pat D.
> Good Luck
> RJ
> of
Reply to Anonymous
VaxX <geoff_gunn@hotmail.com> wrote:
: for your information, the kortek is the same as an imperial monitor chassis.
: Which the manual for it is available on the net.
There are multiple kortek/imperial chasses out there... some are copies of
the 4900, others are copies of the 7000. None of the chasses I've seen match
the schematics I've found on the net.
Mark Spaeth mspaeth@mtl.mit.edu
50 Vassar St., #38.265 mspaeth@mit.edu
Cambridge, MA 02139
(617) 452-2354 http://rgvac.978.org/~mspaeth
Reply to Anonymous
Must be an Australian thing ??? Seems every 20" Kortek is the same as the
imperials..
"Mark C. Spaeth" <mspaeth@plancherel.mit.edu> wrote in message
news:4236fab5$0$563$b45e6eb0@senator-bedfellow.mit.edu...
chassis.
match
> Cambridge, MA 02139
Reply to Vaxx
On a different note, I got my hands on a good but old(read, TUBES!) manual
for an oscilliscope which has all the plans and schematics to build one. Can
anyone convert a tube schematic to a transistor?? Only has 8 tubes in it.
Anyone?
chassis.
match
> Cambridge, MA 02139
Reply to Vaxx
There are 965 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
