Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I am reposting this request for help. For some reason my posts do not appear
the first time, not even after two days.
Had this problem once before on boot up, but can't find the fix for it. On
boot up, I get the message that says "battery voltage low" and I have to hit
F1 to continue or F2 for setup. My battery voltage is NOT low. Does anyone
have the solution to this as it's quite annoying to have the boot stop and
wait for the F1 command? I promise NOT to lose the solution again. Thanks.
"nybarton" <nybarton@adelphia.net> wrote in message
news:1JmdnXzU1dwBLcDfRVn-qw@adelphia.com...
>appear the first time, not even after two days.
> On boot up, I get the message that says "battery voltage low" and I have
> to hit F1 to continue or F2 for setup. My battery voltage is NOT low.
> Does anyone have the solution to this as it's quite annoying to have the
> boot stop and
> Thanks.
This is a repost of my reply to your initial post: Just a guess, but is it
referring to your CMOS battery and might therefore be an early indication
that it needs changing?
The message is generated from your BIOS, so it has nothing to do with
Windows XP. Unless you have removed the CMOS battery (if its a laptop this
is different from the removable battery) and tested it under load, can you
be sure that its voltage isn't low?
Having done a little research since my last posting, a number of people with
Dell computers/laptops seem to have reported this message. In each case the
only reliable solution appeared to be to replace the cmos battery.
Brian, thank you for your response, but I know for a fact that my battery
voltage is NOT low as my computer is only a little over a year old. This
boot up message only appeared this past week after downloading and
installing a couple of different programs. I had this problem once before
when my Dell was only a few months old, so I know it's not the battery. At
that time, someone had the solution for the problem which, if I remember
correctly, did not involve the CMOS. But, unfortunately, I did not save it
the solution. Can you think of anything else besides CMOS? Thanks.
"Brian Cryer" <brianc@127.0.0.1.activesol.co.uk> wrote in message
news:1113485467.28362.0@lotis.uk.clara.net...
>> boot stop and
>> Thanks.
> with Dell computers/laptops seem to have reported this message. In each
> case the only reliable solution appeared to be to replace the cmos
> battery.
> Brian
> www.cryer.co.uk/brian >
news:Y-GdnaMZ15ph58PfRVn-1w@adelphia.com...
> At that time, someone had the solution for the problem which, if I
> remember correctly, did not involve the CMOS. But, unfortunately, I did
> not save it the solution. Can you think of anything else besides CMOS?
> Thanks.
As I understand it, the message is being generated by your BIOS, so I think
its very unlikely to be related with anything you have downloaded or
installed (unless you did a bios update?).
I spoke to Dell about the problem via online chat. The tech suggested I do
this...
Go into system setup
Press down key to highlight maintenance
Press down key to highlight load defaults
In the right pane highlight continue and hit enter
Press the enter key, highlight yes, and press enter again
Press F10 key then press enter
Exit and reboot
(end quote)
Not having a dell, this doesn't mean much to me, but it might make sense to
you - but if you don't have a dell I suppose it won't either!
No, you do not know for a fact that your battery voltage is not low from the
mere fact that your computer is only a year or so old.
Jim
