Ok here is my system first because I just upgraded chip and gfx card, used to have a 1600xp w/geforce fx5600xt
currently now:
Gigabyte ga-7vax
amd 2500xp barton
Micron 512MB PC2700 (2X256mb)
Ati HIS 9800PRO ICEQ 128mb
Audigy2 ZS Soundcard
Cdrom, cdrw, 40g hd, 80g hd, window fan, front light, back fan
Thermaltake Butterfly 480PSU with blower fan
Ok... now the issues...
My games work great, look fantastic except the fact that after a little while they will just reboot!! Once the screen went blank and it said "Out of range" HUH?
I have the Vid card power cable hooked directly from the PSU and from that it is hooked up to the 3 case fans and front light. I did not use the y adapter cable supplied because my nice PSU comes with 9 molex cables.
Ok, one other thing, in hardware monitor it tells me that my core is 1.7volts and my aux is 2.28... it is in red but it has been that way before with my nvidia card and ran stable. I updated the bios, because I had to to be able to use the 2500xp. I also uninstalled the nvidia drivers and used det destroyer and driver cleaner. I have not updated the cat drivers for the vid card, just used drivers it came with but surely that cant be the problem.
I dont understand this though... I hope this is not ruining my system but I dont think it is. I dont know how to check the heat on my ati card but the cooler that is hooked on to this thing is awesome! My hardware monitor tells me that my athlon runs cooler than my system. Pretty cool, but the athlon is 33regular and about 39full load... my cpu is about 35regular and 40load. SO.. my temp isnt hot at all. Please someone help! The graphics are awesome, computer is pretty fast except for loading windows, kind of slow... oh and I am using windows xp home editions with sp1.
currently now:
Gigabyte ga-7vax
amd 2500xp barton
