Archived from groups: microsoft.public.windowsxp.help_and_support (
More info?)
Way to go, Baz
Mike Hall
MVP - Windows Shell/user
http://dts-l.org/goodpost.htm
"Baz" <Baz@discussions.microsoft.com> wrote in message
news:5BB9E919-088F-44F3-9C7D-5789326107C7@microsoft.com...
> Thanks again Mike sorted it out cheers
> "Baz" wrote:
>> Thanks Mike yes I mean the list of programs fills the screen and more.
>> How do
>> I locate the START MENU when finding what I thought was the start menu it
>> doesnt list all the programs I see after clicking start/all programs
>> "Mike Hall (MS-MVP)" wrote:
>> > Baz
>> > If you mean that the list of programs fills your screen and some, you
>> > need
>> > to locate the START MENU and create subfolders into which you can then
>> > place
>> > programs of the same type.. you might have folders like Multimedia -
>> > Games -
>> > Graphics - Office - Security etc
>> > Mike Hall
>> > news:16944378-C658-4E75-A321-AB5AB63B4CE1@microsoft.com...
>> > > When clicking on Start/all programs the screen doesnt show me all the
>> > > programs installed I have the resolution set at 1024*768 pixels which
>> > > is
>> > > good
>> > > for my eyesight but misses quite a lot of the programs installed. How
>> > > can
>> > > I
>> > > view these without changing the resolution?
