Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problems with Radeon 8500
Forum Graphic & Displays : Graphics Cards - Problems with Radeon 8500
I just got my self a brand new Radeon 8500 for my second computer, everytime I start the system the screen is green and really distorted.
The problem is because everytime the computer starts it defaults to YPbPr mode rather than monitor mode. Once I switch to the monitor mode everything is fine...untill I restart the computer that is.
ATI says that the issue was fixed with the newest driver, but im using the latest drivers and its still happening.
Anyone had a simlilar problem? Know how I can sort it out?
P4 2.6@3.38
512Mb PC4000
2x120Gb 7200.7 in RAID0
Waterchill KT12-L30
Abit AI7
Ge-Force4 Ti4200
Sponsored Links
Anyone?
P4 2.6@3.38
512Mb PC4000
Waterchill KT12-L30
Abit AI7
Ge-Force4 Ti4200
Reply to jammydodger
Don't know. That seems like it would be a function of Display Properties, setting the default display device that is.
Did you try Omega's Drivers, <A HREF="http://www.omegacorner.com" target="_new">www.omegacorner.com</A>?
<b>56K, slow and steady does not win the race on internet!</b>
Reply to phsstpok
Yeah, I have the exact same problem. My monitor was kind of a non brand-name one which switched companies later on. I think it's called Likom now. I'm assuming you're running Windows XP. It took me a while to figure this one out but here's what you do. Don't turn on the monitor until Windows has logged on. Just wait for the logon sound, then turn it on. The green stuff goes away after that. I'm not sure why, but it works for me.
If that doesn't fix it then you can boot it up with another monitor that works, then once Windows has booted, switch the monitors and save that profile in the Monitor tab of the Advanced display properties. Bind that setting to a hotkey. Now when you boot up, even if the screen is green, you can hit the hotkey and it'll reset the monitor and should be fine. If you want to use a certain refresh rate, just download powerstrip and lock the refresh rate.
I hope this helps.
Reply to CowMan
Yeh I have bound a hot key to the monitor now, but its a bit of a bitch having to do it everytime. Ah well guess I will have to live with it.
Well thanx for your help anyway.
P4 2.6@3.38
512Mb PC4000
Waterchill KT12-L30
Abit AI7
Ge-Force4 Ti4200
What is the refresh rate you got set so far? Tried 60hz?
Mobile Barton 2500+ @ 2420mhz 11x220 1.7v
Asus A7N8X Dlx 440 FSB
1gb Geil GD pc3500 Dual Channel (2-3-3-6)
Segata 80gb SATA 8.5ms seek
ATI Radeon 9800 Pro(420/730)
Reply to addiarmadar
In ATI's Display Tab, Monitor Properties, force the refresh rate to 75Hz or 60Hz, and select a proper maximum resolution..not sure this helps, but you could always try
Reply to Nights_L
There are 1074 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
