Help Needed: GO7-CBO Screen Problem
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I do not know the technical words to describe the problem. The screen
bends on the right side. Mounted vertical with the chassis/bottom on
the left, so this would make it the top. the top/right bends over to
the top or left. it can be seen in the picture.
http://www.classicarcade.org/g1.jpg
I have already done a cap kit and this did nothing to fix this problem.
Any ideas?
Thanks,
A!
G
Guest
Guest
That's known as 'flagging' or 'curling'. When you did the capkit did
you do the sync upgrade too?
G
Guest
Guest
It is a GO7, 13"
No adjustments seem to make any change to this problem.
Also tried moving the sync around :(
G
Guest
Guest
I just replaced the caps as detailed in the kit I received. not sure if
sync upgrade was part of it.
