G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hello,
I'm running XP Prof + SP2. I just purchased a Philips Key 013 mp3-stick and
cannot get my PC to work with it. It can't be a hardware problem, as the
stick is working with other XP-PCs as well as with 98 with no problems.
At my computer, the hardware seems to be detected (no problems to see in
Hardware Manager), it also appears in tray (safe disconnection or so), but I
cannot see it in WinExplorer nor disconnect it via tray icon. I've tried it
with and without producers drivers, installed all possible UBS drivers new -
nothing helps.
Any ideas? Thanks in advance!
Gosiak
"Your head is round so the thoughts can change their direction"
Hello,
nothing helps.
Gosiak
