Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
have dell dimension 4400 - 1.7ghz / pent 4 operating with XP home (SP1&2) -
with it a microtek 6800 scan master
since installing sp1, have had a problem getting the Scanmaster software.
sometimes (rarely) it conects to the scanner most times I get either it can't
find the scanner at all or that the scanner is being used by another apps.
Microtek is impossible re warrantied software and despite its a good products
will never buy another product from them.
no matter the response from Scanmast, I've been able to acces the scanner
via XP's scan wizard. sometimes in the past I've been able to go into task
manager and by process of random elimination, managed to get whatever in XP
was holding the program to let go and then the Scanmaster programs works ..
and works fine.
until I can find out a way to solve the over all problem and/or buy a newer
pc.... can anybody tell me what are the app kernels that I can eliminate in
task manager so the Scanmaster program will use the scanner ...
I'm in a more immediate need for this scanner and don't have the time to
experiment (I should have documented my previous "succes" )
thanks in advance for any help
Sponsored Links
Go to start/run, and type: devmgmt.msc
Look for a conflict on the port for the scanner, (and perhaps a printer) on an LPT port.
and
click the + sign next to Ports(COM & LPT). select the printer port, e.g. ECP Printer Port (LPT1). Port Settings tab check the
'Enable legacy Plug and Play detection'
Mark L. Ferguson (NOT an MS-MVP)
FAQ for MS Antispyware version 1.0.509
http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
marfers notes for windows xp http://www.geocities.com/marfer_mvp/chatNotes.htm
"Leo" <Leo@discussions.microsoft.com> wrote in message news:DE9202BB-2C77-4E0F-B01E-F4092E1CCA75@microsoft.com...
> and works fine.
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > scanner problem
There are 783 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
