Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
hello everybody,,
I am facing a problem, after I installed new msn messenger 7...
i'm thinking that the problem may be because of conflict between windows
messenger & msn messenger,, i log on using my id on hotmail.,,, and problem
starts, first it automatically log on to windows mesenger & then after some
time it log off itself & log on using msn messenger...
This happens because both windows messenger and msn messenger are
conigured to start at boot time.
Both of them try to login to your account on hotmail.
You may consider to disable one of them. Either use Windows Messenger
or use MSN Messenger.
To Disable Windows Messenger on Windows XP.
Click Start->Settings ->Control Panel
Click Administrative Tools
Click Services
Double click Services Scroll
down and highlight "Messenger"
Right-click the highlighted line and choose Properties.
Click the STOP button.
Select Disable or Manual in the Startup Type scroll bar
Click OK
hi i recently upgraded to msn 7 and when i did it wont let me sign on, it
tells me in connections that i am not currently connected to .NEt messenger
service plz help..
"~Krunal" wrote:
> hello everybody,,
> Is there any way to solve it....
> thank you
> krunal
