Application installation problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I am trying to reinstall Apple iTunes and iPod Updater using InstallShield
and am getting the message "String xxx not found in the string table" where
xxx is PRODUCT_NAME, I_STRING110, etc. I'm running XP Pro SP2. Apple
support is useless and InstallShield says to contact Apple. Any help would
be appreciated.
Thanks.
W Weldin
G
Guest
Guest
check the eventlog for a message that states, what component or file
triggered the windows installer
try to copy the installer files from your cd to your local machine and
run installation again.
superdrool
superdrool's Profile: http://forums.techarena.in/member.php?userid=2396
View this thread: http://forums.techarena.in/showthread.php?t=84484
Visit - http://forums.techarena.in
