Tom's Hardware Forums » Games General » Games General Discussions » Weird problem with WG 25K7193
Word :   Username :
Bottom
Author
 Thread : Weird problem with WG 25K7193
More Information
Archived from groups: rec.games.video.arcade.collecting (More info?)
I've got a WG 25K7193 that runs fine until I *barely* flex the
board. If I give it just the slightest push in the area around the
heat sink on the right, above the RGB+Sync inputs, the high-voltage
cut off circuit kicks in. I can't find any bad components, bad solder
joints or broken traces. What could cause this?
Please see my arcade and pinball items for sale:
http://www.videoracer.com/forsale/
Or check my repair logs:
http://blog.videoracer.com/blog/
Related Product
More Information
R89 has broken away from the copper pad. You won't see it until you
actually unsolder it.
Sometimes I've actually had the HV shutdown pot go bad.
Google Ads
News
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Quantum attacks worry computer scientists
Published on November 03, 2006
In the weird world of quantum computing, the state of computer systems networked together is so fragile that a read access to a single quantum bit, or qubit, on one machine would require a network-wide reset. Read more
Millions Hit In Southern Florida Power Outage
Published on February 26, 2008
People in southern Florida were hit with a massive power outage after two nuclear reactors spontaneously shut down. The outage centered on the Miami-Dade area, but also extended to some parts of Broward County. Nuclear Regulatory Commission reps say the reactors were probably responding to a weird reading in the power grid and add that everything should be back to normal shortly. Read more
CES goes pink with Hello Kitty
Published on January 12, 2007
Most booths at the Consumer Electronics Show are pretty bland, but Spectra International's booth stood out with several walls of eye-searing pink Hello Kitty electronics. The cat face with its trademark missing mouth, a symbol of international cuteness, was plastered on everything from phones to USB sticks. There were even Hello Kitty toasters and hair dryers on display. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
