I have problem power problem with my hp g62 laptop
Last response: in Laptops & Notebooks
June 23, 2012 2:14:19 PM
i have a hp g62 laptop, i press the power button but it wont on at all. i have press down the power button more that 60 seconds still nothing happen. please what else can i do?. i brought out the board and check its component but i could not figure out anything there. Pls help out. Can I get board diagrams. Thanks
a b D Laptop
a b α HP
June 23, 2012 2:24:13 PM
if there no led on the mb/laptop with a know good ac power block and or a fully charged battery it could be the laptop power board or system board. if your using just the ac power check that the ac block is working..most times that the part that fails or the pin where the ac block plugs into the laptop breaks off or the pin shorts out the mb.
m
l
June 23, 2012 2:55:15 PM
i guess the problem is not from the power block etc. cos when i open up the board, i read it with my digital meter it shows that 19vdc get to the power ic but still not working
m
l
