G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I'm having a problem with the HaS thing. It tells me a driver I installed may
cause problems and so windows is disabling it. I get this message EVERY time
I start up. It also tells me to go to a few websites to update the driver,
Roxio, Real, and some other site. I'm tired of receiving this message,
especially since I uninstalled the program (Roxio EZ CD creator 6) because it
didn't work with WinXP. So how about this... Instead of telling me some
driver is causing a problem and having windows whine about it, have it
actually TELL ME WHAT DRIVER SPECIFICALLY IS CAUSING THE PROBLEM SO I CAN
REMOVE IT. Thank You.
