Tom's Hardware Forums » Games General » Games General Discussions » TECH: WG 4600 Monitor issue (shorted)
Word :   Username :
Bottom
Author
 Thread : TECH: WG 4600 Monitor issue (shorted)
More Information
Archived from groups: rec.games.video.arcade.collecting (More info?)
Hello,
I screwed up big time. If you have been paying attention to this board
for the last couple of days you might have seen my earlier posts. I
finally got the chassis working after a cap kit.
Well, here's the problem. While I was trying to find the B+ voltage,
the leads slipped and ended up shorting from the tr502 blue lead to the
ground. Obviously, this is really bad. The monitor immediately
stopped working. The fuse burned out and I replaced it today. After I
did this, I fired it up and it survived for about a second before the
fuse broke again.
So.. Any ideas? I'm thinking I might have to replace both TR501 and
TR502 but I'm not sure at this point. There is a whole power board on
this chassis and I'm afraid it might need to be replaced completely.
Once again, any ideas would be appreciated. Either reply to this or
e.mail me at jake dot vanorder at gmail dot com.
Thanks.
--jake
Related Product
More Information
502 should be replaced for sure and when that went it probably took 501
with it. Mainly replace those two transistors and that should fix it.
That power board unplugs easily for service. Just unlatch those black
plastic 'pull knobs' at each end of that power board assembly and pull
the board straight up. Be careful to look first at the connector on
this board before pulling it up as the factory put a small white
'beaded' wire tie thru a hole in the circuit board to secure it to the
main monitor board. You'll have to cut that wire tie and discard it.
More Information
Ken,
Thanks for the reply. I'll take a look at replacing those two
resistors. Do you know where I can pick some up?
As for the power board, I think it is also screwed in at two places but
it should be no problem to remove.
Thanks for the help.
--jake
More Information
Those are transistors not resistors. They are located on the plugin
power regulator board at the far left (as viewed from the rear of the
monitor). Any good local electronics parts jobber should have them.
Look in your Yellow Pages under the heading, "Electronic Parts &
Supplies". If no local suppliers then mail order them from Bob Roberts.
The power/regulator board on a 4600 series should not be screwed in
place. As shipped from the factory it is only held by a black (or
sometimes white) plastic pull knob similar to the old Datsun car
fusebox cover lock knob. Simply just pull the knob up about an eigth of
an inch to release the latch prongs under it. Then cut the little white
plastic beaded wire tie near the connector. The board pulls straight up
and out for service.
More Information
I didn't know about that knob release. I saw those but didn't know
what they were for. Weird. I'll look up the parts when I have a
chance.
Thanks for your help!
--jake
Google Ads
News
LCD-monitor OEM prices continue to fall in December
Published on December 02, 2004
LCD-monitor OEM prices are expected to drop this month, with 15- and 17" monitor quotes to drop US$3-5 and 19" monitor prices to fall US$5-10, according to Taiwan-based monitor makers. Read more
BenQ 2ms LCD monitor to hit the market in November
Published on October 27, 2005
BenQ recently debuted its 2ms 19" LCD monitor (FP93G X), which it claims to be the world&'s fastest monitor. Read more
LCD monitor vendors betting on widescreen models
Published on November 15, 2005
First tier LCD monitor vendors such as Acer, BenQ, ViewSonic, Hewlett-Packard (HP), Samsung Electronics are all eying the large size widescreen LCD monitor segment, though some panel makers hold a more conservative attitude toward the widescreen market, according a Chinese-language ET Today report. Read more
LCD monitor makers report declining shipments
Published on September 12, 2005
Taiwan-based LCD monitor makers posted mixed results last month with most manufacturers, including BenQ and Lite-On Technology, experiencing a drop in LCD monitor shipments, according to the companies. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
