Problem executing Help from the Task Scheduler
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Running XP HOME Edition
When I try to click on help in the Scheduled Tasks program I get the error:
Your current security settings prohibit running ActiveX controls on this
page. As a result, the page may not display correctly.
I have set my browser Internet security to Low, my Local intranet to Low,
and Trusted Sites to Low, but still I get the above error.
How do I fix?
Thanks for any and all help.
BPL
How do I fix?
BPL
More about : problem executing task scheduler
In news:95E164D8-E04D-44D1-9CEC-5D4EB64882B7@microsoft.com,
Bruce Liebman <BruceLiebman@discussions.microsoft.com> had this to say:
My reply is at the bottom of your sent message:
> error: Your current security settings prohibit running ActiveX
> controls on this page. As a result, the page may not display
> correctly.
> Low, and Trusted Sites to Low, but still I get the above error.
> How do I fix?
Open IE, click tools, click options, click advanced, scroll down, allow
active content to be displayed on my computer. That work?
Galen
Signature changed for a moment of silence.
Rest well Alex and we'll see you on the other side.
> correctly.
> How do I fix?
Galen
Galen,
Thanks for your reply, but your suggestion to, "Open IE, click tools, click
options, click advanced, scroll down, allow active content to be displayed on
my computer.", did not work because nowhere on that advance menu did the
words "allow active content ..." exist.
Thanks for trying.
> > correctly.
> > How do I fix?
> Galen
Galen,
Thanks for trying.
> > correctly.
> > How do I fix?
> Galen
> How do I fix?
Open Internet Properties, go to security Tab, select Internet, go to
custom Level Disable/Enable/Prompt as needed, this should help.
> How do I fix?
Related ressources
- task scheduler - Forum
- Task Scheduler will not run task - Forum
- Help with Task Scheduler utility - Forum
- Echo does not work with task scheduler - Forum
- Win2K Task Scheduler says running but it's not - Forum
In news:2CCCF8DB-6B19-4D1E-883C-1870D04E9E03@microsoft.com,
> Galen,
> click options, click advanced, scroll down, allow active content to
> be displayed on my computer.", did not work because nowhere on that
> advance menu did the words "allow active content ..." exist.
> Thanks for trying.
Okay then let's try this (you haven't updated to SP2 yet?) open IE, click
tools, click options, click security, click on the Your Computer icon, click
on Custom Level, and the ActiveX for the My Computer zone.
Galen
> Galen,
> Thanks for trying.
Galen
Galen,
Thank you for continued interest in my problem.
First off, I did not upgrade to XP SP2. I have a Gateway machine and have
tried doing so on several occassions. Each time I have done so I have
destroyed my machine. I have had both Microsoft and Gateway involved in my
problem and neither one of them were any help. I have decided to forget about
SP2.
I have tried setting everything under the custom settings having to do with
activeX to enable underthe Internet tab, the intranet tab and the trusted
sites tab to enable. Nothing works.
> > Galen,
> > Thanks for trying.
> Galen
Galen,
SP2.
> > Galen,
> > Thanks for trying.
> Galen
Jim,
Thanks for your input.
Please refer to my lastest response to Galen today. In it I told him I have
tried all that he and you suggested. I did this way before I posted to this
board.
> > How do I fix?
Jim,
board.
> > How do I fix?
In news:F2008700-19F5-407B-888A-32796F270AE3@microsoft.com,
> Galen,
> have tried doing so on several occassions. Each time I have done so I
> have destroyed my machine. I have had both Microsoft and Gateway
> involved in my problem and neither one of them were any help. I have
> decided to forget about SP2.
> do with activeX to enable underthe Internet tab, the intranet tab and
> the trusted sites tab to enable. Nothing works.
Well, not one of those zones. The MY COMPUTER zone or the YOUR COMPUTER zone
(I think it was My Computer in SP1) should be where you're playing. When
you're done you might want to go back to the other zones that you've played
with and set them back to normal as some of those settings are VITAL to your
continued security and the stability of your OS.
Galen
> Galen,
Galen
Galen,
I am not a novice with computers, but I do not know where or what the MY
COMPUTER" zone or "YOUR COMPUTER" locates.
In the Internet Explorer, Version 6.0.2800.1106.xpsp2.050301-1536, under the
tools menu -> internet options -> Security tab, there are 4 zones
(1)Internet, (2)Local Internet, (3)Trusted Sites and (4)Restricted Sites.
Nowhere to be found is a zone called "MY COMPUTER" zone or "YOUR COMPUTER"
zone. The zone you are referring to may be in the XP PRO Edition. I am using
XP Home Edition. I have also checked everything under the "MY COMPUTER" icon
I have on my desktop and found no ActiveX settings under the properties.
If I am not looking in the right place please be more specific on how to
where you are referring to.
Thanks again for your continued interest.
Bruce
> > Galen,
> Galen
Galen,
Bruce
> > Galen,
> Galen
In news:AF187415-F693-42F6-9031-41A7341AC871@microsoft.com,
> Galen,
> MY COMPUTER" zone or "YOUR COMPUTER" locates.
> under the tools menu -> internet options -> Security tab, there are
> 4 zones (1)Internet, (2)Local Internet, (3)Trusted Sites and
> (4)Restricted Sites. Nowhere to be found is a zone called "MY
> COMPUTER" zone or "YOUR COMPUTER" zone. The zone you are referring to
> may be in the XP PRO Edition. I am using XP Home Edition. I have also
> checked everything under the "MY COMPUTER" icon I have on my desktop
> to where you are referring to.
> Bruce
Bruce,
Good morning once again. It's raining off and on here in my neck of the
woods. I'm not sure why you don't have a My Computer zone on your computer.
You should. Then again it MIGHT be that it's a tweak that I use that enables
it and it's something that I do to every computer that I use? No worries.
It's pretty easy to get you one... (They're handy to have too and *should*
enable us to get this fixed up in a jiffy.)
http://support.microsoft.com/?kbid=315933
As a second note, and I don't suppose this matters as the point is that you
want it to work, I've never found the Help in XP to give me any information
that I really wanted. I've never really had the Troublshooting Wizard do me
any good either. It's a moot point though when you're just hoping that the
computer will work the way you want it to.
Are you running any software that's preventing this from loading such as a
script blocking tool? Is updating out of the question?
Galen
> Galen,
> Bruce
Bruce,
Galen
Good Morning Galen,
Weather in my neck of the woods (South Carolina) has been cool and windy the
last two days.
I checked out that web site regarding the addition of the "My Computer Zone"
to my machine.
I exported the registry path to my desktop and here is what was displayed:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet]
As you can see no values existed under that key at all.
I hope this addition to the registry was intended to work in XP Home Edition
SP1.
I will try to add the information later in the day when I am fully awake
(had a bad night's sleep last night).
As for the reason I want the help to work, I nolonger remember. I seem to
have been caught up in the fact that it didn't work when I was trying to get
some additional information.
> > Galen,
> > Bruce
> Bruce,
> Galen
Good Morning Galen,
last two days.
to my machine.
SP1.
> > Galen,
> > Bruce
> Bruce,
> Galen
Galen,
Correction - I read the PATH wrong in that article. I found the correct PATH
and verified that the setting was HEX 00000021, I will change to 00000047 and
see what happens. I will get back to you later
Bruce
> > Galen,
> > Bruce
> Bruce,
> Galen
Galen,
Bruce
> > Galen,
> > Bruce
> Bruce,
> Galen
Galen,
After installing the ICON and adjusting the setting as you discribed the
"Task Scheduler Help" now appears to be working properly.
You are the man!
Thanks you very much.
> > Galen,
> > Bruce
> Bruce,
> Galen
Galen,
You are the man!
> > Galen,
> > Bruce
> Bruce,
> Galen
Related ressources:
- ForumTask Scheduler could not execute an EXE written in VB
- Forumtask scheduler problem
- ForumTask scheduler - Help
- ForumTask Scheduler Please Help !!!
- ForumTask Scheduler Service
- ForumTask Scheduler not run
- Forumscheduled task in xp home
- ForumTask Scheduler Error 0x80090016 Keyset does not exist
- ForumCan't start task scheduler
- ForumHELP!!! Please with Windows XP
- Forumhelp: password in bios setup
- ForumDisk Defrag: Compress problem
- ForumWindows Update Problem
- Forumstrange xp sp2 problem
- Forumhtml Help files do not work correctly
- More resources
Read discussions in other Windows XP categories
