Fps games with touchpad/problem
silvex3000
20
how can i keep firing, holding touchpad double tap , while aiming with touchpad right button?
the problem is, when i aim with touchpad right button, it automatically disables touchpad double tap function while held!
there is any solution for this pro?
And they even call you "veterans"! HAHA! I already have a damn mouse! In fact, i have wow cataclysm mouse!
"Get a real computer." from ram1009.
I mean, what'a ***? if you dont know the solution, please, stay quiet!
I'll google for the solution, and if i find one, I will share it with you! damn!
the "veteran" status is given to users with a score system like a post count. to speed up the process, getting best answer in a thread happens. Calling names doesn't get the discussion anywhere. the problem is you're using something designed and engineered for the purpose maximum space savings on a laptop. It was not designed for playing shooter games, hence why the mousepad works that way.
If you already have a mouse, you have your solution.
Touchpads were not made to handle multiple inputs like that. You cab try a higher end wacom tablet or something, or see if a MAC touchpad will do what you want.
silvex3000
20
i finally found tha damn solution!
the problem is not the hardware (Synaptics touchpad)
the problem is in the driver/software (from Synaptics). all versions i think!
i uninstalled the "Synaptics 2009 driver/software" and installed the 2012 version! and guess what? same problem!
so, i uninstalled "Synaptics 2012 driver/software" and restarted windows!
and guess what again? the problem was solved!
damn it, Synaptics! fix this damn problem!
silvex3000
20
just to let you know!
silvex3000
20
