'HELP! My Nokia 8390 doesn't work in my room!
G
Guest
Guest
Archived from groups: alt.cellular.fido (More info?)
I've been with Fido for the past four years and recently moved into a
1st-floor apartment at 125 Bamburgh Circle here in northwest Toronto. Moving
was a chore, but my main concern is the lack of reception in my bedroom. I'm
lucky to get one bar on my Nokia 8390 and it's driving me crazy.
I picked up a SonyEricsson Z200 for testing purposes and it's even worse.
The dilemma is: Do I buy a new phone and switch carriers (Rogers!!!)? Or do
I buy a better Fido phone (ie. SonyEricsson Z600 coming out this weekend)
with the hope of getting a decent reception in my new apartment?
I'm calling on all you Fido experts to give me some advice.
I'm desperate!
[[[Konfucius]]]
G
Guest
Guest
I would not rely on a new phone. If your signal is poor, it is poor.
8390 is a good phone for reception, not the best, but good.
I would talk to Fido, and make it clear that if they can't do anything
about the issue, you are switching.
If you are the only person with a problem there, they probably won't
help, but if there are other complaints in the area, you might get them
to tweak the settings on a tower to assist you.
Their decision as to how important the issue is will depend on what your
revenue to them is, whether it is a simple thing to fix (ie adjust an
existing tower vs adding a tower/microcell) and whether there are other
complaints.
I have seen them respond where the solution was simple. I reported an
issue several years ago at St. Georges School, and they did adjust the
tower a few weeks later, and called me back to say it had been resolved,
which it had.
> I'm desperate!
> [[[Konfucius]]]
G
Guest
Guest
The Z200 is not the best RF performer, it is more of a "style" phone. If
you really want to see if another phone would help, try out a Siemens M55.
Also, the 8390 is know to have quite some bugs (including with reception),
if it does not have the right firmware. Try getting the firmware updated to
at least v.7.80 if you have not already done so. (to check your firmware
revision, press *#0000# on the keypad).
Good luck!
CU
"Konfucius" <konfucius18NOSPAM@rogers.com> wrote in message
news:uqimc.6530$urx.313@news04.bloor.is.net.cable.rogers.com...
Moving
I'm
do
> I'm desperate!
> [[[Konfucius]]]
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.677 / Virus Database: 439 - Release Date: 04/05/2004
G
Guest
Guest
Not sure if this will help for you, but I've noticed when driving along the
401 towards Montreal, my V60i picks up a useable signal noticably sooner
than my 8390. Perhaps a phone like that would be able to pick up enough of
a signal in your location
Moving
I'm
do
> I'm desperate!
> [[[Konfucius]]]
G
Guest
Guest
if all else fails, goto Rogers. with the implemetation of 850 you're more
than likely to get great building penetration.
"Cellular Unlocker" <cellularunlocker@hotmail.com> wrote in message
news:409a595e$1_2@aeinews....
to
> Good luck!
> CU
> Moving
> I'm
worse.
> do
weekend)
> > I'm desperate!
> > [[[Konfucius]]]
G
Guest
Guest
Thanks for the info CU. I have v7.80 right now. Is there a higher version?
[[[Konfucius]]]
to
> Good luck!
> CU
> Moving
> I'm
worse.
> do
weekend)
> > I'm desperate!
> > [[[Konfucius]]]
G
Guest
Guest
There is a newer version, v.8.00, but I don't know if Fido is offering it.
Either way, v.7.80 usually fixes all issues with reception. I suggest you
try another phone (a friend's, maybe), like an M55, which a proven RF
performer. Also, take AndrewH's advice and call CS. They may be able to
tweak the tower settings as he says.
CU
news:kkBmc.19088$urx.16408@news04.bloor.is.net.cable.rogers.com...
> [[[Konfucius]]]
If
M55.
reception),
updated
> to
> > Good luck!
> > CU
> > Moving
bedroom.
> > I'm
> worse.
Or
> > do
> weekend)
> > > I'm desperate!
> > > [[[Konfucius]]]
Version: 6.0.678 / Virus Database: 440 - Release Date: 06/05/2004
