WTB Williams Control Panel Interface PCB
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I have a joust that I am working on and the 2nd player wings wont flap.
I put a control panel interface board in from a stargate and
everything works fine so it must be something in the board or that
ribbon cable. Does anyone have one for sale/trade?
Tim
G
Guest
Guest
I have a defender that wouldn't recognize the control panel. I
replaced the interface board and it still didnt' work. I got the board
from Andre at www.arcadesolution.com so I was pretty sure the board
worked.
He suggested checking for corrosion on the 20-pin header on the CPU
where that board plugs in, and for a quick fix to try taking some fine
sand paper and clean the pins. Sure enough that took care of it.
Doug
G
Guest
Guest
well my stargate board works in there just fine ...I am wondering about
that ribbon cable though
thanks for the tip about Andres sight
tim
