Williams power supplies & 4164's??
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I just got my Joust up and running, I did the Dram upgrade to the
4164's. My question is, the game fires up and runs fine, then from time
to time the +5 VDC led will go out and the game dies. So more or less
I'm wondering if the extra load of the 4164's now using the +5vdc is too
much for the power supply? or do I just need to rebuild the factory
power supply?
G
Guest
Guest
Diamond Dave <grabrr@yahoo.ca> wrote:
: I just got my Joust up and running, I did the Dram upgrade to the
: 4164's. My question is, the game fires up and runs fine, then from time
: to time the +5 VDC led will go out and the game dies. So more or less
: I'm wondering if the extra load of the 4164's now using the +5vdc is too
: much for the power supply? or do I just need to rebuild the factory
: power supply?
Chances are the 4164's use less +5 than the 4116's did...
Mark Spaeth mspaeth@mtl.mit.edu
50 Vassar St., #38.265 mspaeth@mit.edu
Cambridge, MA 02139
(617) 452-2354 http://rgvac.978.org/~mspaeth
G
Guest
Guest
Ok, It's just kinda weird, if I leave it off for a bit the power supply
will work again, I guess I'll have to have a look at rebuilding it.
G
Guest
Guest
On Sat, 09 Apr 2005 23:19:00 -0400, Diamond Dave <grabrr@yahoo.ca>
A friend of mine told me the header pins HAVE to be reflowed because
they are notorious for having cold solder joints.
Eric A.
eavedesianNO_SPAM@comcast.net
313-268-0541
Mr. Propane Torch!!
ELV!S,TZ,Cy(l*ne,FH,STTNG,RFM,BH,HS,HS2,B@by-P@c M@n,St&Sp,Strgte,BK
Remove NO_SPAM_ to reply
G
Guest
Guest
I have a Sinistar game that was doing the same thing and I found that "My"
problem was that Williams used come poor design Molex connectors. mine has
the wires that slide into the connector and cuts the insulation as it goes
deeper. I had 2 bad connections there. all I did was to remove them snip
them back some and reinsert them problem went away.
"Diamond Dave" <grabrr@yahoo.ca> wrote in message
news:BrCdnZ4ZLcrEEsXfRVn-tg@rogers.com...
> power supply?
