Help me, Flash problem.
BadAsh
9
Hey Guys,
I read the Post about flashing my ATI RADEON 9800Pro to 9800XT Speeds and followed the instructions correctly to the point and now I start the computer and it doesn't even P.O.S.T. It starts for about 2 seconds and then It will shut off. What is going on? Is there anyway I can revert this? I am currently running my ATI RADEON 7500 64mb to view and I cannot play the games that I wish to. Can Someone help me?
Thank you in advance.
This is my Boomstick.
GeneticWeapon
Splendid
Jan 13, 2003
5,795
Flash back to your old bios <b>that you saved</b>.
<A HREF="http://rmitz.org/AYB3.swf" target="_new">All your base are belong to us.</A>
<A HREF="http://service.futuremark.com/compare?2k3=2216718" target="_new"><b>3DMark03</b></A>
BadAsh
9
I did save it but I cannot get the Computer to boot up with the ATI RADEON 9800PRO in it. It shuts down after only 2 seconds of being on. The Computer will not even POST.
GeneticWeapon
Splendid
Jan 13, 2003
5,795
You have two choices, you can either blind flash(which isnt too difficult), or you can buy/borrow a pci video card to boot from while you flash your old bios back onto the card.
<b>These kind of problem's are exactly why I didnt want a sticky post to be made of Willamette's 9800Pro>9800XT thread.</b>
BadAsh, see if you can get ahold of a pci video card, and we'll get you fixed up.
BadAsh
9
Thank you GeneticWeapon,
I have actually two PCI Cards.
One is a Rage II+DVD (atleast that is what it says on the chip) I believe it has 4MB of memory.
The other is a MACH64 and I don't know how much memory is on it. Will either work?
Please explain the Blind flash as well.
I appreciate your help.
Crashman
Polypheme
Former Staff
How the hell is he going to reflash the card when the system won't stay powered up with that card installed? Last I knew you had to have a running system to flash a card.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
GeneticWeapon
Splendid
Jan 13, 2003
5,795
I'm pretty sure that his computer isnt shutting off because he flashed his card's bios. I suspect that he simply isnt getting anything displayed on his monitor.
BadAsh, can you tell us if your pc itself still runs?...any light's on or drives spinning?
Crashman
Polypheme
Former Staff
He said in his first post the computer starts for 2 seconds and shuts off!
GeneticWeapon
Splendid
Jan 13, 2003
5,795
Read the original post again Crash, he's using the computer to post these messages on. He simply changed out the video card to a Radeon 7500 AGP.
GeneticWeapon
Splendid
Jan 13, 2003
5,795
I'm pretty sure that if he set's his pc up to boot off the pci card, his system will stay running.
BadAsh
9
When I put the ATI 9800Pro in, The computer boots for two- three seconds max. The it turns off. I have to turn it back on to get it going again(meaning it will stay on for two - three more seconds and shut off.) While the ATI 7500 is in it it keeps working. Does that make more sense? I don't think I worded it correctly the first time.
BadAsh
9
OK. I have put both a PCI (MACH64) and the ATI 9800PRO into another computer and It will stay on if I have PCI selected in BIOS as my first Video to be accessed. Now If I Flash the card will it flash the MACH64 to the original?
Since it is an ATI card as well?
GeneticWeapon
Splendid
Jan 13, 2003
5,795
GREAT!!.. when you type "<b>atiflash -p 0 whateverbios.bin</b>"...the zero designates the AGP slot, so you dont have to worry about mistakingly flashing your pci card :wink:
And of course, where I have "whateverbios.bin" typed, you are to enter the name of the bios you are flashing to(your original)
GeneticWeapon
Splendid
Jan 13, 2003
5,795
Alrighty:)
GeneticWeapon
Splendid
Jan 13, 2003
5,795
Yay!!!
GeneticWeapon
Splendid
Jan 13, 2003
5,795
Well...I've been through it all before with that 9500Pro I had.
didnt you burn that one up?
also what ever happened to that beautiful 8500le you had?
"This Steel ain't stainless, Your bloodstains are all over this steel."
<A HREF="http://www.cameronwilliamson.com" target="_new">-={Messianic Maniac.}=-</A>
<font color=green>{FLM}</font color=green>
GeneticWeapon
Splendid
Jan 13, 2003
5,795
I broke it...yes. It's now buried deep in Canada somewhere (Grape's house)
That card is in my parent's machine:)
