I bought a graphics card and i got it and i opened my case excited like a kid at x-mas, and i popped the card into the previously empty slot. I closed everything and i started it up. I got all excited and windows kicked up and i loaded the game i had bought in hopes of playing endlessly. Everything worked fine till i booted up the game. Screen went black...well i guess it was mostly black with a flicker or two of what was going on behind it. As soon as the computer wanted ANYTHING to be rendered in 3D my card crapped out and i had to reboot.
I tryed many games, i tryed Rhino, i tryed anything i could think of and they all failed once the need for anything in 3D. I figured i needed new drivers, no big deal i went on the company website and got the drivers. I DL'd them and installed. No change.
I am not a computer guru by any means but i am not without experiance either. I have an alright computer and i was hoping to upgrade the pieces i could before a major overhaul of the Mobo, Processor, and whatnot.
I have a Athlon XP1700, 512MB RAM, and some Mobo i dont know. I have a Compaq Presario and i tryed what i know to look it up and cant find it. I would like to install an MSI FX5600 VTDR128.
I can't figure out why it wont work. is there something inheirently wrong with my computer? card? my instalation?
I completely uninstalled the card and tryed to reinstall it, and even after that the same thing happens. I also had trouble with some of the software bundled with it. my computer would recognize the card and loaded 90% of the software for it but one disk would pause about half way through and then i would have to reboot.
I took a midrange 64MB card from a friend that was his old one to use for games. (yes, i am aware that its not the greatest card but it was free and i am not playing FarCry here...) I am forced to use lower res. and crappy options to play. its not bad but it could be WAY better.
I would think it might be the card but it works fine if i just surf the internet or do something that doesn't require it to do any rendering.
I am so lost, maybe its a quick fix i dont know about, maybe something about my Mobo can't handle the card, maybe the card is bad, maybe something else....i dont know.
I tryed to give as much info as i could, i dont mean to be anoying its just that i am so lost.
thanks for any help you can give
