Archived from groups: alt.sys.pc-clone.dell (More info?)
Appreciate advice/info on replacing XPS T500 power supply as it makes
whining noise:
Where can I get the power supply? (Couldn't find the item on Dell
support.)
Is there a Web page or document spelling out step by step procedure?
Looking at the unit, I am clueless just taking it off. Can't
determine which screws are the "magic" ones that will take out the
unit.
The power supply attaches with either 3 or 4 screws (I forget which) to the top
rear of the chassis. Don't worry if you remove the wrong screws. The chassis
will not then collapse in a heap of metal and plastic... Ben Myers
>whining noise:
>support.)
>unit.
>Thanks for advice/info.
>Clueless
Contact me offline via email at ben_myers@charter.net .
Dell no longer sells these power supplies as spares or replacements. I have
some in computers in my warehouse. Used, but with 90-day warranty. And you DO
need a Dell-branded power supply because the ATX form factor power connector to
the motherboard is wired differently than the standard ATX... Ben Myers
>whining noise:
>support.)
>unit.
>Clueless
> whining noise:
> support.)
> unit.
> Clueless
If you are very careful and respect the voltages to be found in a PSU,
you can access the PSU fan, peel off the metallic disk label in the
center covering the bearing, and CAREFULLY oil it with the minutest
drop of oil on the end of a toothpick or cocktail stick. This often
cures a squeaky fan.....DON'T do it if you are not confident of what
you are doing.
On Wed, 16 Feb 2005 22:57:52 GMT, ben_myers_spam_me_not @ charter.net
That's very reassuaring! Now armed with "confidence", am going to try
the oiling method "peter" mentioned first. Thanks very much for
prompt response, and the offer of the unit in the other post.....
Clueless
>>whining noise:
>>support.)
>>unit.
>>Clueless
On 16 Feb 2005 15:26:48 -0800, peterfelgate@hotmail.com wrote:
>> whining noise:
>> support.)
>> unit.
>> Clueless
>you are doing.
Got the confidence I needed from Ben, am going to try your suggestion.
And I have Radio Shack Lubricator to boot! Thanks for oiling
solution..... Clueless
