Archived from groups: rec.games.video.arcade.collecting (More info?)
my monitor just stoped working and I'm looking for a new one.is happ
controls the best place to get one was looking at there pentranic
$551.00 seems to be cheapest
Is your monitor not worth fixing? If the tube is in good shape and you
are a novice, just get a brand new chassis and have it installed. Or,
pull the whole monitor and find a TV repair man that will work on it
and it usually will be a lot cheaper than a new monitor.
i had put a cap kit in it and it was doing ok .picture was dark and
took awhile to warm up and would lighting up then it just died i
figured just get a new one and be done with it
Were are you located? Have you looked into having the tube Rejuvinated?
I do repair and rejuvination of tubes in the Chicago Area.
I have seen a lot of drak n thought to be dead tubes come back to life
with a decent picture.
Go directly to Wells Gardner at http://www.wells-gardner.com/ and look under
the medium resolution section. You'll find Med Res 27" new for $395 and
refurbs for $310 plus shipping. Keep in mind that poor picture quality can
also be cause by failing components on the PCB.
Pete
<drmoonsparkle@aol.com> wrote in message
news:1113757197.686718.203190@f14g2000cwb.googlegroups.com...
> I have two used 27" monitors. One was just recapped recently.
> Call if interested, my old aol account was closed years ago.
> Mark C.
> 419-494-4584
> 419-354-3448
> djmoonsparkle AT hot mail DOTT com
