Toshiba Satellite A300 Problem
Last response: in Laptops & Notebooks
July 12, 2012 11:18:23 PM
Hi, im having a problem with a Toshiba Satellite A300, the problem is that when i turn the laptop on, after the toshiba logo the screen stays black, the fans go louder but the screen stays black. I tried everything, removing battery, starting without battery, reseting bios settings, didnt work. Even when i set the boot device to cd/dvd and put in a cd the screen stays black after toshiba logo. Sometimes after toshiba logo i get blue vertical lines but they disappear after 1-2 sec. Im guessing it might be HDD, System or Screen problem but i dont know.
a c 248 D Laptop
July 12, 2012 11:22:35 PM
Hi :)
Try an EXTERNAL screen...if that works its the Inverter or Screen gone...
All the best Brett :)
July 12, 2012 11:28:52 PM
i just tried it there, external does not work either
a c 248 D Laptop
July 12, 2012 11:39:04 PM
Hi :)
You DID enable the external screen with the Fn key and one of the Functions keys ??
It wont work if you just plug it in....
July 12, 2012 11:44:58 PM
yes i did, and all i get is still toshiba logo, and black screen after that
a c 248 D Laptop
July 13, 2012 1:04:35 AM
Hi :)
If you can get into the bios....its a hardware problem obviously....
Try running a hard drive test in Dos...Hirens cd etc...
