START UP PROBLEMS~ACER INSPIRE ONE MODEL; D225E
Last response: in Laptops & Notebooks
ACER INSPIRE ONE MODEL; D225E PROBLEMS
I NEED HELP!!!!!!! I BOUGHT MY NETBOOK LAST YEAR & IT WORKED FINE UNTIL I WENT TO TURN IT ON THE OTHE DAY!!!! 1ST THE KEYBOARD STOPPED WORKING SO I HAVE TO USE A USB KEYBORAD & THEN IT IT KEEPS ASKING WHERE TO BOOT FROM & WHEN I CLICK WINDOWS 7 IT JUST GOES TO A BLACK SCREEN!!! THEN COMES UP WITH WINDOWS BOOT REPAIR AND THEN DOES NOTHING!!!!
HEEEEELLLLPPPPPP PLLLLEEEAAASSEEE!!!!!!
Looks like you might need to do a system restore; look up the manufacturer's tips for doing so (can go on their website from a different PC and download all the info).
If that doesn't work, you may need to do a clean install.
Using CAPS all the time is the equivalent of shouting in writing; we understand you have an issue to raise, but shouting doesn't help.
Good luck!
Ask the community
