<A HREF="http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=398494#398494" target="_new">http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=398494#398494</A>
(^-the above link follows my problem, though I figured out for myself what was wrong, there are pictures of what was occuring nearer the bottom (other pix are for old card.))
SUMMATION: Had 9700PRO, it was fuxored, RMA'd for new, got 9800Pro in just yesterday, its fuxored, looks like overheating once again, got to testing software drivers etc -nothing helped, just now tested the card fan, its not spinning..
PROBLEM: I can no longer get to my desktop, by the time my sys. loads, as the desktop begins to load up (Explorer) I get VPU Errors/sys. freezes/video resets/loop fuxored -I am not able to load my system fully. My MOBO: ASUS A7N8X has NO video out, must have VPU for monitor output, anyway I can use video through my card w/o actually running the Radeon card/not causing any heat to the chip (I need to be able to at least use 2D on my machine, how is this possible with this hardware ie: not borrowing a card from elsewhere -can I just massively underclock the card/change some BIOS settings/pre-load some grfx configs that change DESKTOP settings (as I can't get to my desktop to change them myself)/run SOFTWARE RENDER MODE that outputs through the card without causing any heat to the chip/running the chip?)
OVERALL: My 9800Pro's fan is not working.
{FROM BELOW: ^^^-Update: The fan rests inside the heatspreader (SEE: NewEGG Pix Link) and I was able to remove the 3 small screws that hold it inplace, hopefully I can get just the FAN from the reseller <AGAIN: Is there any way/place where one can pick up JUST THE FAN for this card for like a couple bucks?} <-Unless its a power issue, as I believe that I may be under powering the card, how can I TEST the fan?
***UPDATE 2
CARD PIX: <A HREF="http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-281&depa=1" target="_new">http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-281&depa=1</A>
</***UPDATE 2>
***UPDATE 1:
FOREMOST:
-Is there a second power connector needed for the card, to reach a higher voltage possibly, beyond what the highest voltage from a single PSU connector can provide?
</***UPDATE 1>
I need some info on the following:
-Power connectors for 9800Pro: If it can fit one from my PSU then its the right Voltage and is correct connector right?
-Info on the Fan of a SAPHIRE 9800Pro: I can't get the HeatSink/Fan unit off the card like I could with Saphire 9700Pro (-which had 2 little plastic push pins that let go of some hooks on the back of the card -9800Pro has something similar, but pushing these, which have a visible spring on the push pins where the other card where plastic cones with no visible springs, doesn't do anything/they're stuck and I don't want to keep putting more and more pressure on them.)
-Can the fan/heatsink unit itself be replaced/sold seperate of the card: Do you think I can get just the heat unit shipped to me seperate.
FAN:
-Anything I can do to 'jumpstart' the fan? I tried 'flicking' it but that doesn't work, tried replugging the tiny fan power connenctor out-of then back into the card too.
(MORE TO FOLLOW)
Thanks.
peace,
<P ID="edit"><FONT SIZE=-1><EM>Edited by i3lueHorneT on 06/27/04 11:58 PM.</EM></FONT></P>
***UPDATE 2
</***UPDATE 2>
***UPDATE 1:
FOREMOST:
</***UPDATE 1>
FAN:
(MORE TO FOLLOW)
Thanks.
peace,
