Remote Assistance and Remote Desktop help
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Well, I'd like to be able to setup either Remote Desktop or Remote
Assistance to help my mother with her computer issues. She only has 2
computers (both XP Pro SP2) connected in a peer-to-peer network via a
Microsoft Base Station (not sure of model yet, bought last year).
Norton Internet Security is used on both computers. I am trying to
access those computers from my home using my Laptop (XP Home SP2). I am
also using ZoneAlarm (free version) and a Linksys Wireless Router model:
WRT54G. So far I haven't had any success with either Remote Access or
Remote Desktop. I've done the basics: Putting a check mark in the
"Allow users to connect remotely to this computer" checkbox, Putting a
check in the boxes under the Windows Firewall settings for both Remote
Assistance and Remote Desktop. What else should I look into. The
message I get from Remote Assistance is ""remote assistance connection
could not be established because the remote host name could not be
resolved. please try agian." and from Remote Desktop is "The client
could not connect to the remote computer. Remote connections might not
be enabled or the computer might be too busy to accept new
connections....etc."
Any help would be appreciated very much
Thanks!
Rob
sonicman99
sonicman99's Profile: http://forums.techarena.in/member.php?userid=5967
View this thread: http://forums.techarena.in/showthread.php?t=90727
Visit - http://forums.techarena.in/archive/index.php/
1 answer Last reply
More about remote assistance remote desktop help
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Rob,
    You said yourmother has 2 XP SP2 PC's in a peer to peer....does the
    Microsoft Base Station accept the incoming TCP/IP request? I don't know much
    about the MS Base Station, but in that case, ensure UPnP forwarding is
    enabled on your mother's router and specify a an external port to hit on the
    router, and 3389 as the internal port. When you connect remotely, you'll
    have to specify the external port. You could either type
    xx.xx.xxx.xxx:(external port # here), or run mstsc /v:xx.xx.xxx.xxx:(port#)
    from the command line.
    Norton Internet Security would have to be configured to allow connections on
    that port. I was a little thrown off about your comment regarding make the
    security changes on Windows Firewall....if you're running Norton, you
    shouldn't have the Windows Firewall enabled for the connection, unless you
    were referring to your computer, in which case the Windows Firewall should
    not be a factor.
    Also, try using remote desktop internally within in your mother's peer to
    peer network. Start by simply testing using the internal address...possibly
    something like 192.168.1.100 and 101. After that, try specifying the outside
    address.
    Hope this helps,
    Jon
    > Thanks!
    > Rob
    > sonicman99
Windows XP
