well i have a Radeon 9800 PRO 128MB, ive studied a couple of threads in here, but couldnt finde anything that match up to my problem.
its been going on for quit some time now, when i boot up in windows and i get that windows loading screen where the little thingie moves from side to side. just before i switches to the login screen, its like a couple of pixel rows suddently jumps a couple of CM to the right. it can be one line, or many and its not everytime windows starts, ive tryed other monitores and the problem still exists.
another thing is, when i run aquamark2003 bench test, i get an ok score 35000Marks, but at diffrent places doing the test my graphic dosnt run smooth .. hmm how to explain this .. well if u take you hand and move it across a smooth surface and the suddently hit some dirt or a none smooth area, just for a micro sec your hand whould slow just in that instance... i dont know if that maid sence, but thats my problem, and the frame rate dosnt drop.
what ive tryed.
diffrent drivers (No change )
reinstalled multible times (No change )
looked for conflict/shareing devices (fixed another problem i had with a game )
turned fastwrite off (Fixed some system stability)
tryed with and without V-sync (No change)
ive tryed with BIOS default and Tweeked (No change)
i allso had the problem with my old computer( just bought the MSI resently)
my system is:
MSI KT6 delta FISR
Athlon XP 2600+ (2130MHz)
1 GB Samsung RAM 333MHz
200GB Sata Maxtor HDD
Sapphire Atlantis 9800 PRO 128MB DDR ram
Hyndai 19" monitor and Compaq V75 17" monitor
the current drivers im useing is Omega ( the newest )
and the card is cooled plenty (not over 50 C)
what ive tryed.
my system is:
MSI KT6 delta FISR
