I have a problem on my inspiron 5100.
It's only 2 months old and I never had this problem before.
It shuts down after a while.
It happens when some CPU demanding process is on. Like DVD player, CPU test program, Win Deafraug. And the overall cpu performance is very weak. Even playing a DivX movie on the background makes the sound all jerky, I am not talking about running several processes at the same time.
It just shuts off without any notice or error.
Bottom of the computer gets pretty hot too.
Who knows what the problem is? What should I do?
Are there any tools to test the CPU performance, temperature?
Use I8kFanGUI from www.diefer.de, to determine exactly how hot your CPU gets while running the above mentioned tasks. It is most likely heat related, the Inspiron 5000 series has been known to overheat. You may need to clean the dust out of your CPU fan. Get back to us, and we'll be able to help you further.
RaPTuRe
Who's General Failure and why's he reading my disk?
That could definitely be the problem. If your CPU is sitting at 72'C at 10% Usage, it is most likely a heat problem. You should take out the fan and clean it (a fairly basic procedure, there is a step by step guide in the support section of the dell.com site under 'reference' - i would link to it, but their site is 'malfunctioning' so i can't get the url) - if it carries on, you should definitely get Dell to service your notebook.
RaPTuRe
Thanks guys
I fugured out what is the critical temperature for my system. At 76C it shuts down - it's about 15 minutes of running at 100% cpu load.
I thought that P4 have some intelligent temperature control or something like that.
I called Dell customer support. They were traditionally unhelpfull. They suggested sending the laptop in their service facility. That would mean at least a weak without computer and a trouble of backing up all data.
I will definitely try to clean the fan.
I recently installed new intel chipset drivers. Can this be a problem. Can it be software related at all?
No, it is certainly not software fault. It really should not be getting that hot, I would recommend you specify fanGUI to switch on the fan at quite a lower CPU temperature. But yes, if cleaning the fan does not work, you should definitely send it in.
The P4 does support thermal throttling, but Dell must've opted to disable this feature (for reasons unbeknownst to me) on the 5100. I know that all the Dells I've owned have supported thermal throttling.
Perhaps you should look on the Dell Support Forums and see if anyone else has had a problem similar to yours?
RaPTuRe
<A HREF="http://premiersupport.dell.com/docs/systems/ins5100/en/sm/thermal.htm#1084976" target="_new">here</A> is the link that I could not post earlier.
RaPTuRe
